February 16, 2016, 16:58 |
error udf opening
abid
Please can any oe help me?
Deleted old libudf\ntx86\2ddp\libudf.dll 1 fichier(s) copi‚(s). (system "copy "C:\PROGRA~1\ANSYSI~1\v120\fluent"\fluent12.0.16\s rc\makefile_nt.udf libudf\ntx86\2ddp\makefile") 1 fichier(s) copi‚(s). (chdir "libudf")() (chdir "ntx86\2ddp")() # Generating ud_io1.h Done. Opening library "libudf"... Error: open_udf_library: Le fichier spécifié est introuvable. Error: open_udf_library: Le fichier spécifié est introuvable. Error Object: # |
February 16, 2016, 17:52 |
Bruno Machado
Rep Power: 13 |
seems that you created a library with one name and you are trying to load something with a different name. The library name you created should be the same you use to load it.
February 18, 2016, 02:32 |
Rep Power: 18 |
Modifying UDFs and reloading them in Fluent can sometimes be tricky, check out my compiling process for Fluent UDFs with an existing library loaded
Static Temperature / Opening Temperature | JulianP | CFX | 12 | April 10, 2019 19:00 |
Opening boundary condition for multiphase analysis in CFX | shivasluzz | CFX | 3 | May 15, 2015 10:49 |
How does CFX treat an opening when heat transfer is modelled? | JuPa | CFX | 2 | September 9, 2014 06:34 |
How to properly set up an opening in buoyancy driven problems | lavoz | CFX | 5 | July 23, 2014 07:06 |
opening sims as a wall. | Curran919 | CFX | 8 | March 19, 2012 22:31 |
