Contact UDF for dynamic mesh problem.
Old   February 15, 2016, 20:12
Default Contact UDF for dynamic mesh problem.
Ahmed Jalal
A.Jalal is on a distinguished road
All,
I am trying to simulate a valve closing in ANSYS Fluent 16.2 and would like to create a UDF that allows me to specify a zone as a porous medium once two walls get very close to each other that way fluid will still pass through without recieving any negative volume errors.
Doe anyone have any suggestions. I am basically modelling a 2D plane of a valve body and a spring loaded poppet.
Thank you
A.Jalal is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Need HELP in writing UDF for a dynamic mesh problem farrux Fluent UDF and Scheme Programming 0 July 3, 2015 03:53
[ICEM] Problem with using the Delaunay volume mesh method manahara ANSYS Meshing & Geometry 12 December 25, 2014 22:54
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
