C_CENTROID macro
Old   February 9, 2016, 22:19
Default C_CENTROID macro
hwet is on a distinguished road
Hi I Have taken the below code from the UDF manual from the example using the DEFINE_INIT macro.
I am wondering how C_CENTROID is able to pin point the location of a cell with the following code. The thread could be containing a lot of cells...Shouldn't it be returning the positions of all the cells in the thread?
C_CENTROID(xc,cell,cell_thread);
if (sqrt(ND_SUM(pow(xc[0] - 0.5,2.),
pow(xc[1] - 0.5,2.),
pow(xc[2] - 0.5,2.))) < 0.25)
hwet is offline   Reply With Quote
Old   February 9, 2016, 23:48
`e`
`e` is on a distinguished road
The macro C_CENTROID(xc,cell,cell_thread) has three arguments: real x[ND_ND] (variable for holding the cell centroid coordinates), cell_t cell (unique integer for the cell within the cell thread) and Thread *t (pointer to the cell's thread).
Check the lines of code immediately above your excerpt:
/* loop over all cells in secondary phase cell threads */
begin_c_loop_all (cell,cell_thread)
This macro loops over all cells within the thread "cell_thread" and returns the cell ID of each one, "cell".
`e` is offline   Reply With Quote
Old   February 10, 2016, 00:13
From the manual
The function sets up a spherical volume
centered at 0.5, 0.5, 0.5 with a radius of 0.25. A secondary-phase volume fraction of 1 is then patched to the cells within the spherical volume, while the volume fraction for the secondary phase in all other cells is set to 0.
This UDF initializes the secondary phase which means that 1)There was secondary phase already in the flow domain+now it was initialized to new values. 2) There was no secondary phase and it was introduced through this initialization. Looping over all the cells should then patch the volume fraction in all the cells in the volume(the whole geometry), not just the spherical volume with radius 0.25. I want to know how these lines patched the volume fraction in this region alone.
Is this similar to the Zone ID's which can be seen/listed in numbers from the GUI. Or can i only give a UDF the cell ID's depending on some 'if' statement of a property in a cell and depend on the UDF to use that statement, get the cell based on that statement and process it with what I want?
Hope I make sense.
Old   February 10, 2016, 00:23
`e`
The DEFINE_INIT macro allows you to have greater control over the initial conditions using a UDF (this macro is called after the initialisation and before the first iteration). The phases should already be created and this macro modifies the initial values.
The example includes a conditional if statement to allocate a volume fraction of either unity (inside sphere) or zero (outside sphere). This statement uses the cell centroid coordinates (found with C_CENTROID) to calculate the radial distance from the origin of the sphere (located at x=y=z=0.5 m).
if (sqrt(ND_SUM(pow(xc[0] - 0.5,2.),pow(xc[1] - 0.5,2.),pow(xc[2] - 0.5,2.))) < 0.25)
    /* set volume fraction to 1 for centroid */
    C_VOF(cell,cell_thread) = 1.;
else
    /* otherwise initialize to zero */
    C_VOF(cell,cell_thread) = 0.;
The thread ("t") can be matched to the cell zone IDs but the cell number ("c") is unique for each cell within a thread.
Old   February 10, 2016, 00:40
Now it makes sense!!! woah
So difficult to understand all this UDF science
Macro within a Macro beyonder1 Tecplot 1 September 4, 2015 19:33
StarCCM+ Command line options and Macro execution isidp STAR-CCM+ 8 January 29, 2013 06:00
Macro Trouble -Winows Explorer Crashes with Macro Martin Castillo FLUENT 1 July 25, 2007 05:18
Macro problem cfddummy Siemens 1 April 9, 2007 13:37
Call a macro from a macro Flav Siemens 2 July 1, 2004 06:42
