Fluent disappears while starting
Old   February 7, 2016, 07:48
Exclamation Fluent disappears while starting
sphoenix09 is on a distinguished road
Hi all,
The fluent was working fine earlier without giving any environment variables to run an UDF, but after setting environment variables, i tried to start fluent with SDK, its opens and then disappears leaving behind the cortex error message as follows.
Error [cortex] [time 2/6/16 21:12:3]
C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.0\cort ex\win64\cx1500.exe received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error [cortex] [time 2/6/16 21:12:5] Cortex received a fatal signal (SEGMENTATION VIOLATION).
Error [cortex] [time 2/6/16 21:13:22]
Error [cortex] [time 2/6/16 21:19:25]
Error [cortex] [time 2/6/16 21:19:27] Cortex received a fatal signal (SEGMENTATION VIOLATION).
How to solve this problem? Any help would be appreciated
Thank you
sphoenix09 is offline   Reply With Quote
Old   February 8, 2016, 23:33
`e`
`e` is on a distinguished road
Uninstall whichever SDK software you're using (unless you need it for something other than Fluent) and remove the environment variables you've set. Then, install Microsoft Visual Studio Express (free); ensure the version you install is compatible with your Fluent version. If you get stuck, there are a number of threads on this topic as well as the Fluent FAQ page.
`e` is offline   Reply With Quote
Old   February 15, 2016, 12:56
Question Need help - Transient analysis
Thank you for the reply. I installed new VS and SDK and its not giving any error now.
I am newbie to multi phase analysis and simulating a sloshing problem with sinusoidal motion of rectangular and cylindrical tank.
displacement = 0.01*sin(7*time)
I used the following udf to compute. Is this correct udf for such problem?
#include "udf.h"
#define omega 7
#define a 0.01
DEFINE_SOURCE(xmom_source, c, t, dS, eqn)
	real source;
	real time=RP_Get_Real("flow-time");
	if(time < 10)
		source = - omega * omega * a * sin(omega * time) * C_R(c,t);
		dS[eqn] = - omega * tan(omega * time) * C_R(c,t);
	else
	source = dS[eqn] = 0.0;
	return source;
here source term is acceleration. I'm not sure about this.
Any help would be appreciated.
Thank you.
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 07:47
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Starting Fluent on multiple machine diamondx FLUENT 0 July 22, 2011 17:41
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 17:41
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 07:41
