February 3, 2016, 03:18 |
uff error
Zheng Mengyi
Rep Power: 10 |
i want to build a simple electric potential using udf for practice
and here is the simple code #include "udf.h" DEFINE_ADJUST(potential,domain) { Thread *t; cell_t c; face_t f; real x[ND_ND] thread_loop_c(t,domain) { begin_c_loop(c,t) { C_CENTROID(x,c,t); C_UDSI(c,t,0) = 10.*x[2]; } end_c_loop(c,t) } } when i try to interpret udf the error comes line:10 parse error line 12 c_loop_last:undeclared variable i can not figure out where is wrong with this two line (thread_loop_c(t,domain) and begin_c_loop(c,t)) and i wander if there anyone can give me some help? any advise will be a big help for me thank you |
February 3, 2016, 06:56 |
Bruno Machado
Rep Power: 13 |
you missed the ; after the real x[ND_ND]
February 3, 2016, 23:37 |
Zheng Mengyi
Rep Power: 10 |
February 4, 2016, 06:51 |
Bruno Machado
Rep Power: 13 |
February 4, 2016, 21:14 |
Zheng Mengyi
Rep Power: 10 |
thanks for your reply
since it was the first time to use UDF and may have lots of thing i don't know. i use this code just try to give UDSI0 some value which did not work know. As you replied i think you mean i have to set the transport equation and set boundary condition, and the UDSI0 should be calculated by fluent rather than give it by user directly? again thank you sincerely |
February 5, 2016, 05:59 |
Rep Power: 27 |
If you want to store the potential in a memory location, I think you should have a UDM (User Defined Memory), not a UDS (User Defined Scalar).
C_UDMI(c,t,0) = 10.*x[2]; |
February 5, 2016, 07:52 |
#7 | |
Bruno Machado
Rep Power: 13 |
If there is no source term, field is not affected by flow and also there is no need to compute gradient, you can use UDM to define it, as Pakk said. If any of the previous mentioned considerations are false, you need to define it through UDS; If so, you need to define the domains it is solved (in the menu, Domain -> User Defined -> Scalars) and also the diffusivity of it in the materials menu. |
February 8, 2016, 23:22 |
#8 | |
Zheng Mengyi
Rep Power: 10 |
February 8, 2016, 23:24 |
#9 | |
Zheng Mengyi
Rep Power: 10 |
fluent - udf |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
