January 6, 2016, 22:33 |
UDF for nanofluid effective properties
Aarthy Meena
Rep Power: 10 |
Hello all,
I am trying to model nanofluid flow over a 2D circular cylinder using mixture model based multi-phase approach. In literature, I see that the effective properties of the mixture are calculated using theoretical models. But, FLUENT by default calculates it by averaging. I understand that a UDF can be written to this. But, I am unable to guess to which property this UDF must be assigned. Because, in boundary conditions and material properties only the particle and basefluid properties are required to be feeded. Please help me understand this. Thanks in advance. Happy New Year.
Aarthy, PG Student, National Institute of Technology, Trichy, India. |
February 10, 2017, 18:15 |
nanofluid
ali sarlak
Rep Power: 11 |
hi dear friend
did u find any ufd to change proprty? thanks |
February 20, 2019, 01:14 |
#3 | |
mohammad faizan
Rep Power: 9 |
Did you find how to write UDF for that, i have also some queries.. 1) How to calculate mixture viscosity, as the secondary phase is solid. 2) At the inlet, velocity is calculated from the Reynolds number where mixture viscosity is required? 3) Also at the inlet Both secondary phase and primary phase has same velocity which is calculated from Reynolds number? |
fluent - udf, nanofluid, udf |
Change porous properties in UDF? | Patrik Blix | FLUENT | 10 | April 23, 2020 14:31 |
Material Properties for Sat. Liquid and Sat. Vapor | Blackhawks84 | FLUENT | 0 | September 17, 2012 19:11 |
How to find Properties of Fluid at specific location, using UDF? | pmghadge | FLUENT | 0 | December 8, 2009 13:53 |
I need UDF help. | S.Whitney | FLUENT | 0 | October 15, 2007 11:29 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
