unexpected behaviour of UDF - problems with the coordinate system in Fluent
Old   January 5, 2016, 10:51
Default unexpected behaviour of UDF - problems with the coordinate system in Fluent
Sarah Garden
SarahG is on a distinguished road
I have a UDF for a square wave profile for a pressure-inlet zone named ejection which works..
But I noticed it works in a peculiar way. If it says this
pressure = sin(0.52*(t-1.3482)-(5*PI/7));
/* local variables */
if(pressure > 0.75)
F_PROFILE(f, thread, position) = 0.5;
else
F_PROFILE(f, thread, position) = 0.0;
It's on for 3/4 of the cycle and off for 1/4 - totally the other way round to what I expected.
In another instance, a UDF to cause pitching of the aerofoil needed an arbitrary pi/2 to get the sense of the pitching right. I also had to rotate the aerofoil in the mesh to the mean angle or else, if was positioned at 0 degrees, it would rotate entirely in the negative quadrant.
I'm running a couple more simulations now, which I think will work as I expect them to. But does anyone know if there is a particular reason for this? Is there a different coordinate system in Fluent?
Appreciate any input, thanks
SarahG is offline   Reply With Quote
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 23:24
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
How to get the local coordinate Z via UDF or other way in Fluent JoaoSilva Fluent UDF and Scheme Programming 0 July 17, 2015 08:33
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
