Error occurred during calculate mass flux
Old   December 28, 2015, 08:16
Default Error occurred during calculate mass flux
AaronSyu
aronsyu is on a distinguished road
Hello everyone,
I am trying to calculate the mass flux in my multi-phase model using UDF.
Here is the equation below(ignore term (1-beta))
When I wrote all of equation into my UDF, an error occurred.
Error: cx-set-real-entry: wta[2](float)
Error Object: -1.#inf
I've search on Google, but I didn't get too much useful information.
I think the problem occurred due to the syntax error, but still can't figure it out.
Here is my UDF code below
Parameter "p_sat" and "mass_flux" are new code I added.
If I calculate p_sat, mass flux and q_vap, the case will diverge due to Temperature, so I try to reduce the relaxation factor of Energy, but it didn't work.
If I just calculate p_sat and mass flux, the case work well but can't read contour after calculate(The error above will occur.)
Can anyone help me?
Thanks a lot !
DEFINE_SOURCE(laser_source, c, t, ds, eqn)
Thread *pt,*pt2;
int phase_index = 1;
int phase_index2 = 0;
face_t f;
real time,source,sourceup;
real radq,conv,epsi,delfc, y_dir_grad_vof, mass_flux, p_sat;
real x[ND_ND],s[ND_ND];
pt = THREAD_SUB_THREAD(t,phase_index);
pt2 = THREAD_SUB_THREAD(t,phase_index2);
time = RP_Get_Real("flow-time");
C_CENTROID(x,c,t);
s[0]=vel*(time-3.6e-8);
delfc = code ;
source =code;
y_dir_grad_vof = code;
p_sat = 101325*(exp((47.8679*9.86*pow(10,6))/8.314*3533)*(1-(3533/C_T(c,pt)))); //7
mass_flux = sqrt((47.8679/(8.314*2*3.141)))*(p_sat/sqrt(C_T(c,pt))); //8
q_vap = -9.83*pow(10,6)*mass_flux*C_UDMI(c,t,delta)*(((1-C_VOF(c,pt2))*C_R(c,pt))/C_R(c,t));//9
C_UDMI(c,t,psat) = p_sat;
C_UDMI(c,t,mflux) = mass_flux;
C_UDMI(c,t,qvap) = q_vap;
return source;
aronsyu is offline   Reply With Quote
To calculate area averaged species mass fraction from PDF Bharadwaj B S Fluent UDF and Scheme Programming 3 March 8, 2016 03:22
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Mass Flux vs Velocity Inlet Sandra FLUENT 5 July 20, 2005 14:09
total mass flux correction for compressible fluid? Francesco Di Maio Main CFD Forum 0 August 21, 2000 05:23
