UDF for non linier heatflux in volume
Old   December 17, 2015, 00:12
Smile UDF for non linier heatflux in volume
tri nugroho
nugh is on a distinguished road
Please help...
I have a case with non linier heat flux in volume... heat flux following sinusoidal function or normal distribution function in volume.
How to make UDF (user defined function) on Fluent for my case..
nugh is offline   Reply With Quote
How to use a UDF to set the volume fraction in the cells next to a wall? DF15 Fluent UDF and Scheme Programming 33 August 20, 2020 14:36
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
make the inlet volume fraction equal to the outlet - udf syntax error kongl1986 Fluent UDF and Scheme Programming 2 October 27, 2014 14:02
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
UDF resulting in negative volume.. djan Fluent UDF and Scheme Programming 0 February 22, 2012 15:13
