udf for source term
Old   December 9, 2015, 01:05
Default udf for source term
fersim is on a distinguished road
Good morning,
Please help me to write a UDF program for calculate the source term
This source code calculation value of the source term to account for the phase change phenomenon of a material. As the temperature increases (T (t) > T (t-delta t) the material absorbs heat, so the source term is negative. And decreasing temperature (T (t) <T (t-delta t) the material releases heat, so the source term is positive and finally if the temperature remains constant (T (t) = T (t-delta t) the source term equal to the previous value (source at t - delta t).
This code takes into account the hysteresis of a no pure phase change material. That is to say, the source term is different during the heat absorption and release of heat. This source term is written as a polynomial equation (Source = A * T + B).
I inform you that I code is compiled during simulation but there is the following error:
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
This error is caused that this problem does not recognize the temperature at time t delta-t.
#include "udf.h"
DEFINE_SOURCE(terme_source, c, t, dS, eqn)
real source;
real sourrce_previous; /*sourrce_previous= source at t-delta t */
if (C_T(c,t)>C_T_M1(c,t))
source = -5*C_T(c,t)-25;
else if (C_T(c,t)<C_T_M1(c,t))
source = 8*C_T(c,t)+15;
else
source = sourrce_previous;
dS[eqn]=0;
return source;
fersim is offline   Reply With Quote
Old   December 10, 2015, 08:20
Sun
Sun's Avatar
Sun is on a distinguished road
I think the reason you are getting ACCESS VIOLATION error is that you haven't initialized the source_previous variable.
Sun is offline   Reply With Quote
Old   September 15, 2017, 04:50
maziyar ghanikolahloo
maziyarghani is on a distinguished road
Hello
I want to write a negative source term or heat flux UDF which has a linear relation with temperature
I am very beginner in UDF could you help me?
maziyarghani is offline   Reply With Quote
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
UDF for momentum source term Tanmay_Dutta Fluent UDF and Scheme Programming 0 December 6, 2014 07:24
UDF sink term pichai FLUENT 0 October 20, 2010 02:07
UDF Source Term Christian FLUENT 4 August 1, 2009 06:53
UDF Source Term Units? Brian FLUENT 1 October 24, 2005 10:15
