How to fix problem form Interpreted UDFs
Old   November 25, 2015, 03:12
Default How to fix problem form Interpreted UDFs
Piyanat
oTopero is on a distinguished road
when i'm interpreted code.c. it show a massage error about line 15: structure reference not implemented. how to fix it
thank for answer
i hope someone can help me for search the answer
this is code
#include "udf.h"
DEFINE_HET_RXN_RATE(reaction1,cell,thread,hr,mw,yi ,rr,rr_t)
real *stoich_reactant = hr->stoich_reactant;
int gas_index = 0;
int cat_index = 1;
/* int fd_index = 2; */
real R = 8.314; /* Pa.m^3/(K.kgmol) Gas Constant*/
real ca; /* FD - Feed in gas phase index 4*/
real cb; /* MD - Middle Distillates index 3 */
real cd; /* Nap - Naphtha index 2 */
real ce; /* Gas - C1-C3 index 1 */
/* Thread *liq = THREAD_SUB_THREAD(thread, fd_index); */
Thread *gas = THREAD_SUB_THREAD(thread, gas_index);
Thread *cat = THREAD_SUB_THREAD(thread, cat_index);
real k1 = 550.*exp(3.609e3/(R*345.));
real void_g = C_VOF(cell,gas);
/* real k2 = 4.6868*10e17*exp(-5.7755*10e4/(R*C_T(cell,gas)));
real k3 = 1.3508*10e14*exp(-4.9559*10e4/(R*C_T(cell,gas)));
real k4 = 4.4232*10e12*exp(-4.4285*10e4/(R*C_T(cell,gas)));
real k5 = 1.2094*10e13*exp(-4.5902*10e4/(R*C_T(cell,gas)));
real k6 = 85.1715*exp(-1.1627*10e4/(R*C_T(cell,gas))); */
/* if(Data_Valid_P())
ce = C_R(cell,gas) * yi[0][3] / mw[0][3];
cd = C_R(cell,gas) * yi[0][2] / mw[0][2];
cb = C_R(cell,gas) * yi[0][1] / mw[0][1];
ca = C_R(cell,gas) * yi[0][0] / mw[0][0];
*rr = k1*ca*cb*(1.-void_g) ;
oTopero is offline   Reply With Quote
Old   November 25, 2015, 05:06
pakk will become famous soon enough
From the Fluent Help:
Originally Posted by Customization_Manual_1.4.3
The major difference between interpreted and compiled UDFs is that interpreted UDFs cannot access ANSYS Fluent solver data using direct structure references; they can only indirectly access data through the use of ANSYS Fluent-supplied macros.
The code in line 4 is trying to access Fluent solver data using a direct structure reference. As the quote above shows, this can not be done with interpreted functions.
Solution: compile.
pakk is offline   Reply With Quote
Old   November 26, 2015, 05:08
Piyanat
Solution: compile.
i used both interpreted and compile function.there show error both
Problem interpreted Reaction Code oTopero FLUENT 11 November 24, 2015 07:25
Interesting new problem/ trying to fix contacts using a porous zone A.Jalal FLUENT 0 September 24, 2015 16:40
Problem exporting line bodies form Design Modeler to Mesh Editor&Fluent Rockda ANSYS Meshing & Geometry 0 May 26, 2011 12:03
error in interpreted udf's for two macro Asghari FLUENT 0 August 7, 2006 03:10
entropy fix for Riemann problem vivek kumar Main CFD Forum 3 August 31, 2005 08:47
