Create rectified square wave inlet flow profile
Old   November 18, 2015, 13:30
Default Create rectified square wave inlet flow profile
mhw2015 is on a distinguished road
I am trying to create a udf to generate a flow at the inlet that is a rectified square wave (oscillate between 0 and amplitude A). The equations I planned to use were the fourier series of the waveform, namely f(t)=\frac{A}{2}+\frac{4A}{\pi}\sum\frac{sin((2n-1)\omega t)}{2n-1}, but I haven't been able to figure out how to write an infinite sum like this (as n goes from 1 to infinity) in C code for the udf. Does anyone have any insights?
I don't need any specifics for the flow other than this pulsed flow at inlet, the flow can leave the outlet normally as per simulation.
Thank you!
mhw2015 is offline   Reply With Quote
inlet flow profile, square wave, udf
Inlet boundary profile: can I prescribe flow angles? turbomax CFX 9 August 6, 2015 16:01
3D pipe flow :: how to create non uniform inlet profile. thess FLUENT 1 May 30, 2014 03:43
Setting mass flow rate profile at an inlet MentalVacancy STAR-CCM+ 11 July 6, 2012 20:54
Strange velocity profile at the inlet for a flow inside a cylindrical pipe michmich OpenFOAM Running, Solving & CFD 0 July 2, 2012 04:37
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 10:03
