SAving variables using UDF
Old   November 14, 2015, 19:49
Default SAving variables using UDF
Ahmed Jalal
A.Jalal is on a distinguished road
Hello Guys,
I have a question regarding saving certain values into a text file or excel file. Can I save the values that I am asking my UDF to display? In my case DT_CG and Spring Force as shown in the UDF below?
The reason is I want to plot a graph of DT_CG/Spring Force with respect to time.
Any help would be appreciated. I am aware it is a DEFINE AT END Function but I just need help on how to set it up.
Thank You
#include
"udf.h"
#define spring_constant 300 /*N/m*/
#define original_valve_cg_y 0.029972
DEFINE_SDOF_PROPERTIES(spring_check_valve, prop, dt, time, dtime)
real valve_movement_y;
prop[SDOF_MASS] = 0.00297817;
prop[SDOF_IXY] = 3.33709e-12;
prop[SDOF_IXX] = 2.27698e-06;
prop[SDOF_IYY] = 2.53895e-07;
prop[SDOF_IZZ] = 2.53088e-06;
prop[SDOF_ZERO_TRANS_X] = TRUE;
prop[SDOF_ZERO_TRANS_Z] = TRUE;
prop[SDOF_ZERO_ROT_X] = TRUE;
prop[SDOF_ZERO_ROT_Y] = TRUE;
prop[SDOF_ZERO_ROT_Z] = TRUE;
valve_movement_y = (DT_CG(dt)[1] - original_valve_cg_y);
Message(
"DT_CG = %e, %e, %e\n",DT_CG(dt)[0], DT_CG(dt)[1], DT_CG(dt)[2]);
prop[SDOF_LOAD_F_Y] = - spring_constant * valve_movement_y;
Message(
"spring force = %e\n",prop[SDOF_LOAD_F_Y]);
A.Jalal is offline   Reply With Quote
save, txt, udf
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
UDF to read and file flow variables pramode77 Fluent UDF and Scheme Programming 0 December 1, 2014 16:18
Setting up a parametric simulation with UDF variables rohinibc Fluent UDF and Scheme Programming 4 November 19, 2014 11:52
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF for mean variables Gab FLUENT 0 September 28, 2007 17:17
