udf gradients problem
Old   November 14, 2015, 17:04
Default udf gradients problem
Andrej
perun333 is on a distinguished road
Hello guys,
I have problem when Im starting my computing with udf (fatal error). But compiling without problems. I have 2D axisymmetric model, where I want to keeping time and space temperature gradients only in some part of the 2D model. Here is my code:
#include "udf.h"
DEFINE_EXECUTE_AT_END(gradienty)
Domain *domain;
cell_t c;
Thread *ct;
face_t f;
FILE *fw1;
FILE *fw2;
int ID = 1;
real gradient_prostorovy;
real gradient_casovy;
gradient_prostorovy = 0.;
gradient_casovy = 0.;
domain = Get_Domain(1);
ct = Lookup_Thread(domain,ID);
begin_f_loop(f,ct){
gradient_prostorovy = MAX(gradient_prostorovy,C_UDMI(c,ct,0) = sqrt(C_T_G(c,ct)[1]*C_T_G(c,ct)[1]));
gradient_casovy = MAX(gradient_casovy,C_UDMI(c,ct,1) = 3600 * (C_T(c,ct) - C_T_M1(c,ct)) / CURRENT_TIMESTEP);
end_f_loop(f,ct)
fw1 = fopen("gradient_prostorovy.txt","w");
fprintf(fw1,"%lf ", CURRENT_TIME);
fprintf(fw1,"%lf\n", gradient_prostorovy);
fclose(fw1);
fw2 = fopen("gradient_casovy.txt","w");
fprintf(fw2,"%lf ", CURRENT_TIME);
fprintf(fw2,"%lf\n", gradient_casovy);
fclose(fw2);
PS: For next step I would like to make udf for changing heat flux on the wall. If will be gradient_casovy (time_gradient) more then 19 I would like to use heat flux - 10 else +10.
So I would like to do it by this way
DEFINE_PROFILE(muj_profil,t,i)
face_t f;
begin_f_loop(f,t)
if( gradient_casovy > 19. ) {
F_PROFILE(f,t,i)=.....-10.;
else {
F_PROFILE(f,t,i)=....+10.;
end_f_loop(f,t)
I would be happy for help
perun333 is offline   Reply With Quote
fatal error during initialization after udf compilation rik Fluent UDF and Scheme Programming 36 February 21, 2020 16:42
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
Simulation with UDF for species mass fraction and velocity profile virgy Fluent UDF and Scheme Programming 8 February 7, 2012 05:30
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 12:29
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
