Counting number of times a particle hits a wall
Old   November 9, 2015, 14:18
Default Counting number of times a particle hits a wall
davidsq is on a distinguished road
I am trying to write a UDF which tracks how many times each particle hits a wall. I'm assuming that since the DEFINE_DPM_BC macro activates upon particle impact I should use this macro to begin. Additionally in the DEFINE_DPM_EROSION example in fluent help it shows how to track how many impacts occur on a specific face, however I cannot find an example regarding how many times a specific particle impacts the surface.
Any help or guidance for this UDF would be greatly appreciated - even if it's just pointing me in the right directions.
Thanks.
davidsq is offline   Reply With Quote
Old   November 9, 2015, 16:28
`e`
`e` is on a distinguished road
Enable one user-defined value for the particles and increment this value each time the particle impacts a boundary. Use the P_USER_REAL macro for accessing this memory within a DEFINE_DPM_BC UDF.
`e` is offline   Reply With Quote
Old   November 9, 2015, 17:15
Could it be something as simple as the following? I'm getting the error: P_USER_REAL: undeclared variable. I've included the udf.h and the dpm.h header files in the local folder. Not sure why this is happening. Thanks!
#include "udf.h"
#include "dpm.h"
int num_hits = 0;
DEFINE_DPM_BC(num_of_hits,p,t,f,f_normal,dim)
num_hits = num_hits+1;
P_USER_REAL(p,0) = num_hits;
Old   November 9, 2015, 22:11
`e`
Yes, that UDF should work for counting a single particle in serial mode. However, you may encounter issues with tracking several particles (they're counting with the same num_hits variable) and in parallel (num_hits may be different on each compute node). I recommend updating the number of hits with:
P_USER_REAL(p,0) = P_USER_REAL(p,0) + 1.;
The dpm.h header file is already included in the udf.h header file. Enable the particle memory via Discrete Phase Model > UDF > User Variables > Number of Scalars: 1.
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 11:27
Radiation interface hinca CFX 15 January 26, 2014 18:11
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
