Problem in converting 2D udf to 3D code
Old   November 4, 2015, 17:36
Default Problem in converting 2D udf to 3D code
Arman
armanp is on a distinguished road
I am simulating a problem which had been solved in 2D and now trying to convert the code into 3D format to solve the 3D geometry. In this part of my udf (which I present below) I think I might have a problem because answers dont match the experiments like 2D.
face = Lookup_Thread(d, Cell_id);
begin_f_loop(f,face)
F_AREA(A,f,face);
Area = NV_MAG(A);
Cell_volt += F_UDSI(f,face,1)*Area;
Tot_Area += Area;
end_f_loop(f,face)
Cell_volt /= Tot_Area;
I'm new to udfs Do you guys know how I must change this part for getting results like 2D? Thanks in advance for your help
armanp is offline   Reply With Quote
Old   November 5, 2015, 16:18
`e`
`e` is on a distinguished road
This code should work similarly in both 2-D and 3-D simulations. Have you double checked the dimensions, units and achieved mesh independence?
`e` is offline   Reply With Quote
Old   November 6, 2015, 12:33
Arman
Thanks for your response. The model is mesh independent, I've checked that. But, about units in governing equations, I will check them again and get back to you.
Does this problem has anything with solver settings? I'm using PISO scheme. Also, with smaller Time-steps I have better convergence.
Old   November 6, 2015, 21:17
`e`
The problem may be with your solver settings, it doesn't appear to be the UDF at fault. Ensure you have also achieved time-step independence. Are there any 3-D simulations you can compare results with in the literature, perhaps the computational model is inadequate for describing the 3-D effects in this particular case?
Old   November 7, 2015, 08:20
Arman
I think the problem may relate to time-step size. Because, I can't achieve to an independent time-step model! When I raise the time step(up to 1 sec), my results diverge or get into a loop that it couldn't converge. Also, unfortunately there isn't a 3D model of my simulation that I could verify my results with that. There is just that 2D model!
I want to note that almost all of udfs in my 2d model was dimensionless, except a gradient function in which I added the z-direction component. Is it a good approach to just solve the model for a mesh that has been extruded in z for just one cell and then if the answers were good continue adding cells?
Old   November 7, 2015, 18:10
`e`
Yes, you could start with comparing your 3-D simulation with one cell depth versus your 2-D simulation. The results should match, bearing in mind the cell depth length.
What geometry are you simulating? You'll need to achieve time-step independence. Perhaps start with a simpler case (such as a geometry which has steady flow) to validate your model/workflow.
Old   November 8, 2015, 04:23
Arman
Thank you. I will try to simulate that and I'll get back to you.
My geometry is actually pretty simple. It is a box, divided into 4 parts. The Mesh around my walls and boundary conditions is intense.
cfd, three dimensional, two dimensional, udf
fluent udf problem: write specific data for every iteration in a file. nnvoro Fluent UDF and Scheme Programming 1 May 27, 2013 16:26
correct UDF code for unsteady pressure boundary James W FLUENT 0 November 2, 2005 12:38
UDF (write a data file) problem lichun Dong FLUENT 2 July 29, 2005 12:39
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 09:10
