error while interpreting a udf
Old   November 3, 2015, 15:35
Default error while interpreting a udf
atilla savas
atello28 is on a distinguished road
I wanted to interpret the udf below, which would give heat flux on a surface of a domain, but I encountered the errors at the end of the this note. The heat flux is getting greater when the radius gets bigger.
#include "udf.h"
DEFINE_PROFILE(heat_flux,thread,i)
real x[ND_ND];
real radius;
real omega;
real tau;
omega=62.83;
tau=20e6;
face_t f;
begin_f_loop(f,thread)
F_CENTROID (x,f,thread);
radius=sqrt(x[0]*x[0]+x[1]*x[1]);
F_PROFILE(f,thread,i) = radius*omega*tau
end_f_loop(f,thread);
line 19: parse error
line 21: f: undeclared variable
atello28 is offline   Reply With Quote
Old   November 3, 2015, 16:50
`e`
`e` is on a distinguished road
Declare all of your variables at the start of the code block (a requirement of ANSI C which Fluent uses). For example, move "face_t f;" above "omega=62.83;".
`e` is offline   Reply With Quote
Old   November 5, 2015, 07:54
atilla savas
Dear 'e',
I have done what you have said and encountered other errors, can you help me about those as well?
The new UDF and the errors are listed below:
#include "udf.h"
real x[ND_ND];
real radius;
real omega;
real tau;
face_t f;
omega=62.83;
tau=20e6;
line 31 : parse error
line 36: parse error
Old   November 5, 2015, 08:23
atilla savas
Dear 'e',
I found the error by myself:
A semicolon was missing after the line F_PROFILE(f,thread,i) = radius*omega*tau
After I corected it, the interpretation was done without errors but this time I encountered the error below. What can it be the reason?
Thank you in advance...
Atilla
C:\PROGRA~1\ANSYSI~1\v145\fluent\fluent14.5.0\win6 4\3ddp\fl1450s.exe received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Old   November 5, 2015, 16:12
`e`
Looks like Fluent is trying to access something that isn't available. Try compiling the UDF instead of interpreting.
ansys 14.5, fluent - udf, parse syntax
Error during interpreting UDF for VoF vekh Fluent UDF and Scheme Programming 9 March 12, 2018 02:57
parse error while interpreting udf chem engineer Fluent UDF and Scheme Programming 10 September 18, 2015 10:06
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 07:43
Problem with interpreting UDF Boris Kloser Fluent UDF and Scheme Programming 1 December 30, 2009 00:48
parse error with interpreting UDF ivanbuz Fluent UDF and Scheme Programming 2 August 13, 2009 19:29
