Is there a relation between version of fluent and visual basic in compiling?
Old   October 25, 2015, 07:11
Exclamation Is there a relation between version of fluent and visual basic in compiling?
Anwar
4asino is on a distinguished road
Is there any interface between version of fluent and visual basic in compiling ?
I mean; is it necessary for fluent version 14 (for example) to be compiled with visual basic express 2012 ?...
Or for fluent 13 to be compiled with visual 2008 ?... etc,
4asino is offline   Reply With Quote
Old   October 31, 2015, 07:03
Retired Super Moderator
Bruno Santos
Quick answer:
  1. After a quick search for "visual studio fluent" here on the UDF forum:
    Originally Posted by Arvind_CFD View Post
    VS2013 is not supported until Fluent 15.0. Since yours is a much older version VS2008 should work. Make sure you have a full installation with VC++ package and visual studio cross tools command prompt included. Recheck if the check box in the environment tab of fluent launcher is ticked and the path of udf.bat file mentioned in the same tab is correct. Hope this helps
  2. Using Google, I found this: http://www.cfd-online.com/Forums/blo...pile-udfs.html
  3. I'm not familiar with Fluent, but from what I've briefly seen on these forums, Visual Basic is not supported at all. Only Visual C/C++.
Trouble with compiling UDFs in FLUENT cp703 Fluent UDF and Scheme Programming 28 June 1, 2018 04:22
Compiling Fluent UDF with Visual Studio kamnaz Fluent UDF and Scheme Programming 0 August 28, 2014 13:58
need some basic help with fluent udf aarti sekaran FLUENT 8 February 12, 2008 01:57
Compiling error in Fluent eduardo FLUENT 0 December 18, 2007 12:46
Call Fluent from Visual Basic 6 interface AbuKhawlah FLUENT 0 June 5, 2005 15:53
