The fl process could not be started?
Old   October 23, 2015, 11:22
Default The fl process could not be started?
Kadinese is on a distinguished road
Hi team,
I need some help trouble shooting this. I am using a UDF to interpolate a density vs pressure .dat file.
I loaded the UDF fine. But when I try to "execute on demand" I get this error.
- The fl process could not be started.
- Error opening file
Can some please help?
Thank you in advance.
Kadinese is offline   Reply With Quote
Old   November 12, 2015, 16:41
Lei Zhao
leizhao512 is on a distinguished road
Originally Posted by Kadinese View Post
Hi team,
Hi, I guess you were running in parallel mode. So if you want to use the serial UDF in parallel mode, you have to parallelize the UDF first. Go and check UDF manual
leizhao512 is offline   Reply With Quote
The fluent process could not be started Mary FLUENT 5 June 23, 2017 08:38
The fl process could not be started because of UDF majid_kamyab Fluent UDF and Scheme Programming 6 December 15, 2015 09:42
Error: Fluent process could not be started Clem FLUENT 1 November 26, 2015 14:23
the f1 process couldn't be started islam87 FLUENT 1 September 21, 2015 08:33
HELP-error: the fluent process cannot be started James Willie FLUENT 0 January 24, 2006 12:17
