running UDF with linux
Old   October 16, 2015, 17:21
Default running UDF with linux
Rui
roi247 is on a distinguished road
Hello everyone,
I can interpret properly the UDF(c.file) on my own computer. However when I try to use the super computer. My journal file always fails. Could you please help check which part of the jou.file is wrong
parallel/partition/auto/use-case-file-method yes
define/user-defined/compiled-functions compile libudf yes velocity_profile.c "" udfconfig.h ""
define/user-defined/compiled-functions load libudf
file/rcd FFF-2.cas.gz
file/confirm-overwrite no
solve/set/time-step 1
solve/set/reportin-interval 1
solve/dual-time-iterate 10 10
file/write-data FFF-2_1100.dat.gz
/exit
This is the output
[COLOR="rgb(255, 0, 255)"]Warning: An error or interrupt occurred while reading the journal file.
Some commands may not have been completed.
> Halting due to end of file on input.[/COLOR]
Thank you for the help
roi247 is offline   Reply With Quote
how to load UDF in parallel at linux platform maye761 Fluent UDF and Scheme Programming 9 April 13, 2018 04:30
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Running icepak on a linux machine Codemaster FLUENT 0 November 20, 2008 01:50
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
Running Fluent on Red Hat Linux WS version 4 Bob FLUENT 1 September 4, 2005 06:01
