Problem to give different heat flux values over pipe
Old   October 6, 2015, 03:16
Default Problem to give different heat flux values over pipe
SHREEKANT
SHREEKANT is on a distinguished road
I have to give different heat flux values over a pipe with water flow,
the upper portion of pipe that is for 270 deg. i have to give 550W/m2 and for lower 90 deg. 18800 W/m2.
May i please know how to do it? whether i have to define UDF or it can be simply done
SHREEKANT is offline   Reply With Quote
Old   November 5, 2015, 09:38
nurjs
nurjs is on a distinguished road
hi. can i know if you find a solution to your problem. i has the seam problem my results of heat flux not uniform and this lead to obtained a value of bulk temperature larger than average temperature.can any one help me to know whats wrong in my problem.
nurjs is offline   Reply With Quote
Old   November 5, 2015, 16:14
`e`
`e` is on a distinguished road
Have a read of the DEFINE_PROFILE macro in the UDF manual. Then within your UDF, distinguish between the upper and lower portions of pipe with an if statement.
`e` is offline   Reply With Quote
Giving deiiferent heat flux values over pipe SHREEKANT FLUENT 0 September 25, 2015 05:05
buoyantSimpleFoam, problem with additional heat flux karoltomek OpenFOAM Running, Solving & CFD 1 March 12, 2014 10:01
Radiation interface hinca CFX 15 January 26, 2014 18:11
problem with heat flux in the wall gholamghar FLUENT 1 September 14, 2010 08:47
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
