Two phase flow problem
Old   September 20, 2015, 22:21
Default Two phase flow problem
Dawood Al-Mosuli is on a distinguished road
I have fluidization problem with two different types of solid particles. I need to represent the drag coefficient for the interaction between the liquid phase and each of the solids using UDF instead of provided default correlations.
1-Should I provide 2 UDF to represent the drag interaction between liquid phase and each type of solids? (UDF for each case separately)? Or one common UDF is enough to represent both?
2-Should I compile or interpret the UDF. I notice that I can't interpret more than one UDF for the interaction.
3-Should I provide the particle diameter inside the UDF or it will be transferred from the main program?
I am asking about this because I notice that there is a given value [diam2 3.e-4] in UDF example 1-custom drag law in the UDF manual.
Thank you
Dawood Al-Mosuli is offline   Reply With Quote
the mesh adaption problem of gas-liquid two phase flow houwy FLUENT 1 December 6, 2015 20:59
boundary condition problem for 2 phase flow ahmad786 FLUENT 0 September 2, 2013 04:00
Problem with results in 2 phase flow (airstream+rain drops) over s809 wing using DPM yoooodarulez Fluent Multiphase 0 September 1, 2013 17:42
error in two phase flow problem mvee FLUENT 0 March 28, 2007 06:17
Two phase flow problem M.Shannag FLUENT 2 December 29, 2001 13:43
