Passing value in UDF Fluent
Old   September 19, 2015, 03:58
Default Passing value in UDF Fluent
Surya
hariswch2 is on a distinguished road
Hiii friends
I write the Udf program for analysis, in that two functions used namely DEFINE_EXECUTE_AT_END and DEFINE_SOURCE.
I would like to know how to pass some variable from DEFINE_EXECUTE_AT_END function output as an input to DEFINE_SOURCE
i.e., if variable 'x' is an output from DEFINE_EXECUTE_AT_END function, it is the input to DEFINE_SOURCE function.
I tried by defining 'x' as global variable but still DEFINE_SOURCE function not taking as 'x' an input.
Could you plz give suggestions
Thanks in advance
hariswch2 is offline   Reply With Quote
fluent udf, saving data in udf mohsen zendehbad Fluent UDF and Scheme Programming 15 June 14, 2017 00:23
DEFINE_DIFFUSIVITY udf in fluent maniek940 Fluent UDF and Scheme Programming 2 August 13, 2013 18:13
UDF for Viscoelastic Fow in Fluent skris2009 FLUENT 2 September 20, 2011 00:59
udf fluent 6.3.26 don't work in fluent 12 enry Fluent UDF and Scheme Programming 16 September 9, 2010 03:44
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 11:16
