parse error while interpreting udf
Old   September 16, 2015, 10:55
Default parse error while interpreting udf
Lida
chem engineer is on a distinguished road
hi everyone
I face the following error while interpreting the udf that is written as follows:
cpp -I"C:\Fluent.Inc\fluent6.3.26/src" -I"C:\Fluent.Inc\fluent6.3.26/cortex/src" -I"C:\Fluent.Inc\fluent6.3.26/client/src" -I"C:\Fluent.Inc\fluent6.3.26/multiport/src" -I. -DUDFCONFIG_H="<udfconfig.h>" "H:\CO2.c"
Error: H:\CO2.c: line 29: parse error.
Error: H:\CO2.c: line 109: parse error.
the udf is:
/* udf for mass transfer of CO2 in DEA solution */
#include "udf.h"
#undef C_TYPE
#define C_TYPE(c,t) ((int) C_STORAGE(c,t,SV_TYPE,uchar_fl *))
DEFINE_MASS_TRANSFER(CO2_DEA,c,t,from_phase_index, from_species_index,to_phase_index,to_species_index )
real m_lg=0;
real xy=0,dxx1=0.000015,dxy1=0.00015,xc0[ND_ND],xc1[ND_ND],k=0,hy=0,ly=0,my=0,ny=0,py=0,ay=0,mc=44.01,mh=34. 08,mch=16.04,mw=18.02,ma=105.14,ml=148.14,mm=1.01, mn=106.15,mp=33.07,area=0,x=0,cg=0,cl=0,hcw=2916.3 2,hnw=3994.42,hnm=5095.5,hna=0,u,kg,kl,yy=0,hsy=0, y,xi=0;
cell_t c0,c1;
Thread *t0,*t1;
int ii=0;
int jj=1;
Thread *gas=THREAD_SUB_THREAD(t,ii);
Thread *liq=THREAD_SUB_THREAD(t,jj);
real xc[ND_ND];
real xf[ND_ND];
C_CENTROID(xc,c,t);
if(C_VOF(c,liq)>0.1 && C_VOF(c,liq)<0.9)
face_t f;
Thread *tf;
int n;
c_face_loop(c,t,n)
/*loops over all faces of a cell*/
f=C_FACE(c,t,n);
tf=C_FACE_THREAD(c,t,n);
F_CENTROID(xf,f,tf);
if(BOUNDARY_FACE_THREAD_P(tf)) /*return TRUE if Thread *tf is a boundary face thread.*/
if(xc[1]>xf[1] && fabs(xc[1]-xf[1])>1e-8)
xy=F_YI(f,liq,0);
hy=F_YI(f,liq,1);
ly=F_YI(f,liq,2);
my=F_YI(f,liq,3);
ny=F_YI(f,liq,4);
py=F_YI(f,liq,5);
ay=F_YI(f,liq,6);
dxy1=xf[1]-xc[1];
if(xc[1]<xf[1] && fabs(xc[1]-xf[1])>1e-8);
yy=F_YI(f,gas,0);
hsy=F_YI(f,gas,1);
if(xf[0]<xc[0] && fabs(xc[0]-xf[0])>1e-8)
dxx1=xf[0]-xc[0];
else /* if thread is not a boundary face thread */
face_t f;
Thread *tf;
int n;
f=C_FACE(c,t,n);
c0=F_C0(f,tf);
c1=F_C1(f,tf);
t0=THREAD_T0(tf);
t1=THREAD_T1(tf);
C_CENTROID(xc0,c0,t0);
C_CENTROID(xc1,c1,t1);
if(xc0[0]<xc[0] && fabs(xc[0]-xf[0])>1e-8)
dxx1=xf[0]-xc[0];
if(xc0[1]>xc[1] && fabs(xc[1]-xf[1])>1e-8)
yy=C_YI(c0,gas,0);
hsy=C_YI(c0,gas,1);
if(xc0[1]<xc[1] && fabs(xc[1]-xf[1])>1e-8)
xy=C_YI(c0,liq,0);
hy=C_YI(c0,liq,1);
ly=C_YI(c0,liq,2);
my=C_YI(c0,liq,3);
ny=C_YI(c0,liq,4);
py=C_YI(c0,liq,5);
ay=C_YI(c0,liq,6);
dxy1=xf[1]-xc[1];
if(xc1[0]<xc[0] && fabs(xc[0]-xf[0])>1e-8)
dxx1=xf[0]-xc[0];
if(xc1[1]>xc[1] && fabs(xc[1]-xf[1])>1e-8)
yy=C_YI(c1,gas,0);
hsy=C_YI(c1,gas,1);
if(xc1[1]<xc[1] && fabs(xc[1]-xf[1])>1e-8)
xy=C_YI(c1,liq,0);
hy=C_YI(c1,liq,1);
ly=C_YI(c1,liq,2);
my=C_YI(c1,liq,3);
ny=C_YI(c1,liq,4);
py=C_YI(c1,liq,5);
ay=C_YI(c1,liq,6);
dxy1=xf[1]-xc[1];
}a
/* x & y & delta x & delta y are defined */
k=hnm*hcw*C_R(c,liq)*(C_YI(c,liq,0)/mc+C_YI(c,liq,1)/mh+C_YI(c,liq,2)/ml+C_YI(c,liq,3)/mm+C_YI(c,liq,4)/mn+C_YI(c,liq,5)/mp+C_YI(c,liq,6)/ma+C_YI(c,liq,7)/mw)/(hnw*(101325+C_P(c,gas))/1000);
/* k=equilibrium constant & k=y/x */
area=fabs(NV_MAG(C_VOF_RG(c,liq)));
x=xy/(xy+ay*mc/ma+hy*mc/mh+ly*mc/ml+my*mc/mm+ny*mc/mn+py*mc/mp+(1-xy-ay-hy-ly-my-ny-py)*mc/mw);
y=yy/(yy+hsy*mc/mh+(1-yy-hsy)*mc/mch);
cl=C_R(c,liq)*(C_YI(c,liq,0)/mc+C_YI(c,liq,1)/mh+C_YI(c,liq,2)/ml+C_YI(c,liq,3)/mm+C_YI(c,liq,4)/mn+C_YI(c,liq,5)/mp+C_YI(c,liq,6)/ma+C_YI(c,liq,7)/mw);
cg=C_R(c,gas)*(C_YI(c,gas,0)/mc+C_YI(c,gas,1)/mh+C_YI(c,gas,2)/mch);
u=fabs(C_U(c,t));
kg=2*sqrt(1.410191e-5*u/(3.1416*2*fabs(dxx1)));
kl=2*sqrt(1.3741e-9*u/(3.1416*2*fabs(dxx1)));
xi=(kl*cl*x+kg*cg*y)/(kl*cl*+k*kg*cg)
m_lg=kl*mc*cl*area*(xi-x);
if(m_lg<20 && m_lg>0)
{return m_lg;}
else
{return 0;}
line 29 and 109 are bold with red color
could anyone help me with this error?
chem engineer is offline   Reply With Quote
Old   September 16, 2015, 11:21
Bruno Machado
Bruno Machado is on a distinguished road
did you try to compile this udf? maybe this error happens because you are trying to interpreted it.
Bruno Machado is offline   Reply With Quote
Old   September 16, 2015, 11:28
Lida
while compiling I face this error:
> Deleted old libudf\ntx86\3ddp\libudf.dll
The system cannot find the file specified.
(system "copy C:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\3ddp\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "ntx86\3ddp")()
Done.
"C:/Fluent.Inc/ntbin/ntx86"
Opening library "libudf"...
Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
Old   September 16, 2015, 11:42
Bruno Machado
1 file(s) copied.
(chdir "libudf")()
Done.
Error Object: ()
I dont think this error is related with the UDF. It is probably related with your compiler. Try to make a simple udf and see if it compiles. If it doesnt, have a look in other topics how to fix compiler issues.
Old   September 16, 2015, 13:28
Lida
I tried some other udfs. they are compiled and there is no problem. I use microsoft visual studio to compile udf.I don't know what the problem is.
Old   September 17, 2015, 05:03
Default udf fluent
golriz
gzamiri@gmail.com is on a distinguished road
I have problem in compiling UDF in ANSYS FLUENT.
I have installed Visual studio:Microsoft Visual Studio 2013
My ansys fluent is fluent 12.1.2.
I write my code in Microsoft Visual Studio and i don't compile code in Microsoft Visual Studio then i load this code in fluent as follows:
define/user-defined/compiled
The error it is showing while loading is :
'nmake' is not recognized as an internal or external command,operable program or batch file.
Please anyone help me how to get out of this problem.I am using 64-bit system with Windows 8.
gzamiri@gmail.com is offline   Reply With Quote
Old   September 18, 2015, 03:39
Lida
you should'n open fluent directly. you should open it from visual studio in this way:
first open microsoft visual studio. then click on ''tools'' tab and click ''visual studio command prompt'' under this tab. you should write the directory of fluent.exe (using the function cd, as it is used in cmd) then you should type fluent in the command prompt.this way fluent will be open via visual studio and you can compile your udf there.
if you had any problem in this procedure or if something is not clear to you, you can ask
Old   September 18, 2015, 06:35
golriz
dear chem
Thank you very much for suggestion. I try your suggestion. I compile my code in visual studio then I try build compiled code in fluent as follows
define-user_defined-functions-compiled
unfortunetly I observed previous error in fluent
Please suggest me if there is any mistakes.
Thank you,
Old   September 18, 2015, 07:00
Lida
how do you compile your cod in visual studio?where do you write your code?
Old   September 18, 2015, 07:12
Lida
you should write your code in a notepad then change its format to a .c file.then do the process i explained to open fluent via visual studio.at the end in that fluent compile your udf by the directory: define-userdefined-functions- compile.and add your udf by .c format in source files part.then click build to build your library then click load and your udf is ready to use.
Old   September 18, 2015, 10:06
golriz
dear chem
Thank you very much , your advice solved my problem!
Parse Error:- Interpreting UDF on remote terminal moataz.che FLUENT 1 March 7, 2017 15:13
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 07:43
parse error with interpreting UDF ivanbuz Fluent UDF and Scheme Programming 2 August 13, 2009 19:29
Parse Error Message While interpreting UDF in FLUENT dhimans Fluent UDF and Scheme Programming 1 July 10, 2009 07:29
PARSE ERROR Message when interpreting UDF in FLUENT dhimans FLUENT 0 May 24, 2009 12:40
