Parse error interpreting UDF
Old   September 10, 2015, 18:03
Default Parse error interpreting UDF
Mario Alberto
mrwts is on a distinguished road
Hi guys!
I am new learner of FlUENT and UDF and I have been having some problems creating an energy source whose position changes respect to time. The coordinates of the energy source are saved in a extra text file. I have been looking for a while and I haven't found the mistake anywhere.
Trying to interpret the code I am getting the following mistake:
cpp -I"C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.7/src" -I"C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.7/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.7/client/src" -I"C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.7/multiport/src" -I. -DUDF
ONFIG_H="<udfconfig.h>" "C:\Users\Mendez\Desktop\energy source\Airfoil source - arrays with modulus.c"
Error: C:\\Users\\Mendez\\Desktop\\energy source\\Airfoil source - arrays with modulus.c: line 10: parse error.
I add the beginning of code so you can examine the part of the problem:
#include "udf.h"
#define V 1;
#define vel 2;
#define power 1000;
FILE *fp;
int i;
int j;
real a[1021][1021];
fp = fopen("values.txt","r");
for (i=0; i<1022; i++) {
for (j=0; j<1022; j++) {
fscanf(fp,"@d",&a[i][j]);
real t;
t = CURRENT_TIME; // line of the error
real s;
s = t*vel;
DEFINE_SOURCE(energ_source, cell, thread, dS, eqn)
real z[ND_ND];
real source;
real SOURCE_X_POSITION;
real SOURCE_Y_POSITION;
C_CENTROID(z,cell,thread);
Thanks in advance.
mrwts is offline   Reply With Quote
Old   September 14, 2015, 04:51
upeksa is on a distinguished road
You must declare the variables at the beginning of the code.
FILE *fp;
int i;
int j;
real t;
real a[1021][1021];
real s;
for (i=0; i<1021; i++) {
for (j=0; j<1021; j++) {
t = CURRENT_TIME;
s = t*vel;
You must use this code in a DEFINE_ON_DEMAND macro.
Check the size of the arrays.
That should be enough. Cheers.
upeksa is offline   Reply With Quote
Old   September 14, 2015, 17:45
Default Source code, new error
Mario Alberto
Thanks, It solved one of the problems. But, after declaring the variables at the beginning and adding the DEFINE_ON_COMAND marcro, an error comes up regarding two lines
DEFINE_SOURCE(energ_source, c, t, dS, eqn) // showing parse error and in the source line saying that the variable source hasn't been declared.
It seems really unusual for me, let me add the that part of the code so you can give your opinion.
DEFINE_SOURCE(energ_source,c,t,dS,eqn)
real source;
if (t_m % 2 != 0)
source = power/V;
dS[eqn] = 0;
return source;
I was thinking about the source name maybe, because the rest seems normal to me.
Should the name of the source,in my case energ_source, match with the names written in the macros DEFINE_SOURCE, DEFINE_ON_COMAND and the name of the UDF file?
Thanks again
airfoil 2d, energy source, udf and programming
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 07:43
parse error in transient udf spring FLUENT 1 July 6, 2010 07:26
UDF parse error at profile function line Wiggy Fluent UDF and Scheme Programming 1 July 27, 2009 16:59
PARSE ERROR Message when interpreting UDF in FLUENT dhimans FLUENT 0 May 24, 2009 12:40
UDF parse error on line 1 ..... (Unusual) Amit Maha FLUENT 4 June 30, 2006 13:15
