Defining a Loss Coefficient after Run
Old   September 10, 2015, 11:42
Default Defining a Loss Coefficient after Run
Alex
MrNavierStokes is on a distinguished road
Hello CFD-Community,
I am currently working on a 2D simulation of a flow-through cascade and would like to use a UDF for the post-processing task. I have no experience in C language at all and need some help.
The UDF should use the Facet-Maximum value of the total-pressure on the INLET to define the loss coefficient \zeta_{(y)} as a new variable called "Zeta", so I can later use "Zeta" to calculate the mass-averaged value of it over a defined plane.
So I need the UDF to take the Facet-Maximum value of the total-pressure on the INLET and calculate:
\zeta_{(y)} = \frac{p_{tot,max,inlet} - p_{tot (y)}}{\rho \cdot c^{2}_{inlet}}
Where p_{tot (y)} refers to the Facet values of the total-pressure on a plane in my flow-field.
So how do I start?
I hope somebody can help me.
Thank you very much!
Regards
MrNavierStokes is offline   Reply With Quote
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Velocity profile disturbance due to loss coefficient rks171 Main CFD Forum 3 May 25, 2012 18:30
porous medium - defining loss coeff for two fluids sudhakar CFX 0 December 9, 2006 09:11
Loss coefficient at openings Forrest CFX 1 June 11, 2005 19:09
Need help for loss coefficient of elbow diffuser Pete Main CFD Forum 0 November 9, 2004 03:54
