Simple Serial to Parallel UDF conversion Fluent
Old   August 29, 2015, 21:14
Default Simple Serial to Parallel UDF conversion Fluent
Amir
amir00251 is on a distinguished road
Hi everyone,
I am new to UDF and I need help on converting below simple UDF to parallel processing compatible.
#include "udf.h"
DEFINE_SDOF_PROPERTIES(box, prop, dt, time, dtime)
prop[SDOF_MASS] =20;
prop[SDOF_IXX] =200;
prop[SDOF_IYY] =300;
prop[SDOF_IZZ] =300;
thank you.
amir00251 is offline   Reply With Quote
Old   August 30, 2015, 07:48
Engr. Shah Jahan
shahjehan13 is on a distinguished road
This code should also work in parallel. just ensure you are compiling ur udf.
For parallel case, care is taken while summing or global reduction operations.
Good luck.
shahjehan13 is offline   Reply With Quote
Old   September 1, 2015, 05:32
Amir
Hi, thank you very much, as you said problem was about settings of UDF compilation not with parallel processing.
fluent, udf
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
PROBLEM in UDF on parallel fluent mode rakadit Fluent UDF and Scheme Programming 0 July 13, 2012 07:51
Transient pressure UDF for parallel fluent droberts Fluent UDF and Scheme Programming 5 October 11, 2010 05:13
parallelization of serial Fluent UDF for surface reaction sri31049 FLUENT 0 September 8, 2010 15:15
Help for Fluent udf on parallel computing KAILI FLUENT 0 September 18, 2008 01:52
