August 5, 2015, 06:15 |
Pressure force calculations by FLUENT UDF
Rakesh
Rep Power: 12 |
Hi all,
I am using a UDF to calculate the pressure force on the surface of a wing which is deforming under aerodynamic forces. A part of the code is shown here: begin_f_loop(f,t) { F_AREA(A,f,t); PF_x+ = F_P(f,t)*A[0]; PF_y+ = F_P(f,t)*A[1]; PF_z+ = F_P(f,t)*A[2]; ForceP = ForceP + F_P(f,t)*NV_MAG(A); } end_f_loop(f,t) The code works fine as a whole, but when I compare the pressure force components with that reported by FLUENT GUI (going to Results --> Reports --> Force Reports, the results don't match. However if I compare the pressure surface integral (from FLUENT reports) and ForceP (shown above in the code), they match. I am not sure why this discrepancy. Please let me know if you have any idea. Best Regards, RS |
August 5, 2015, 12:16 |
Andrew Kokemoor
Rep Power: 14 |
Remember that force is a vector, not a scalar. When you integrate the pressure over an area, you want the component of that force in a certain direction, not the total integral of pressure over that area. Your definitions of PF_x, PF_y, and PF_z look correct, have you compared those to your force report? (You'll need to include wall shear to get the full force value, but those should match the pressure contribution.)
August 5, 2015, 12:39 |
Rakesh
Rep Power: 12 |
Hi Andrew,
Thank you for the reply. As I already stated, the results obtained for PF_x, PF_y, PF_z don't match the force reports from FLUENT. I am somewhat confused now. F_P(f,t) gives me the pressure acting on a certain face, right? Now if I multiply this pressure (scalar) with the effective area along any direction, I should arrive at the force acting in that direction? However I am not able to find the same value as reported by FLUENT force reports. But as I said, if I multiply magnitude of area with this pressure (scalar) and sum it, I obtain the same value as reported in FLUENT surface integral report. I am not sure how FLUENT calculates the x-face, y-face and z-face area. Can that be a reason for this? |
August 6, 2015, 10:35 |
Andrew Kokemoor
Rep Power: 14 |
Yes, it sounds like you have the right idea, and your code looks right. When you make a force report, it will give you the net force in the direction you specify, but also break it down into the contribution from pressure and the contribution from wall shear. Your UDF should match the pressure contribution.
January 24, 2018, 04:59 |
#5 | |
hashem
Rep Power: 10 |
i have the same problem could you finally fixed it? |
How to read pressure at discrete points | paka | OpenFOAM | 16 | April 28, 2020 07:26 |
UDF for specific heat as function of pressure | ghobold | Fluent UDF and Scheme Programming | 20 | August 22, 2019 08:19 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 14:32 |
Setup/monitor points of pressure and force coefficients | siw | CFX | 3 | October 22, 2010 06:07 |
