UDF Dynamic Meshing for Rotation and Translation
Old   August 4, 2015, 00:57
Post UDF Dynamic Meshing for Rotation and Translation
Aidan Holt
Aidan100 is on a distinguished road
Hey,
I'm learning how to use UDF's in order to set up a transient solver within fluent to test for dynamics involved with a morphing wing in between steady state solutions/morphing.
I am beginning with a simple 2D case and trying to learn how to rotate and translate basic objects in 2D (before progressing to 3D). I am trying to simulate the rotating cylinder to achieve lift and have attached the following UDF which should be able to define the rotational motion about the z-axis. (Source: http://projekter.aau.dk/projekter/fi...Enclosures.pdf)
udfexample.c
UDF for rotation of cylinder
# include "udf.h"
DEFINE_CG_MOTION ( rotation_udf_45 , dt , vel , omega , time , dtime )
real pi = 3.141592;
real omega_constant = 45* pi /180;
omega [2] = omega_constant ;
However after interpreting my UDF and applying it to the cylinder (zone 8) within the Dynamic Mesh menu bar it says:
"Warning: incorrect cg motion UDF rotation_udf_45 on zone 8 (assuming no motion). "
Indeed there is no motion occurring when the preview mesh motion is selected. How can I solve this problem?
Aidan100 is offline   Reply With Quote
Old   August 5, 2015, 07:50
Default Still very stuck, I'm sure there's a simple solution!
Aidan Holt
I've been reading up and it seems a common mistake for UFD beginners like myself. What I have read is:
You need to 'compile' a define_CG UFD before being able making it usable within dynamic mesher.
Although I can build/compile the above UDF, another error appears saying the libudf is unable to be used for parallel use on Windows 64x. So I tried reopening my setup process in fluent using a 'serial' instead and I get the following error:
Error: The UDF library you are trying to load (C:\Transient Analysis_files\dp0\FFF\Fluent\libudf) is not compiled for 2ddp on the current platform (win64).
Thankyou kind CFDonline people in Advance!
Aidan
Old   August 17, 2015, 00:39
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
This problem arises due to problems in installation of Visual studio. In addition to that you should have correct combination of Fluent version and Visual Studio version.
Far is offline   Reply With Quote
dynamic mesh, fluent - udf, motion dynamicmesh, transient, udf
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
UDF applied dynamic mesh and mesh motion in the same time lostmmind Fluent UDF and Scheme Programming 7 April 6, 2015 10:57
sinusoidal horizontal translation udf in ansys fluent shivshankarnair FLUENT 1 September 19, 2014 07:40
Dynamic Meshing 2D whole domain translation newtbeard FLUENT 0 April 5, 2013 10:56
UDF MESH DYNAMIC Benzamia FLUENT 1 May 8, 2006 15:59
