Reload udf from udf?
Old   July 29, 2015, 07:37
Default Reload udf from udf?
Leb
V.Leb
Leb is on a distinguished road
Is it possible to reload a udf from inside itself?
I currently face a problem of using dynamic mesh. I have periodic data in a .txt file, the first cycle is read fine, but the second one is not read (I think the culprit is
if (NODE_POS_NEED_UPDATE (node_p))
              /* Set flag to indicate that the current node's        */
			  /* position has been updated, so that it will not be   */
              /* updated during a future pass through the loop:      */
              NODE_POS_UPDATED (node_p);
Since FLUENT probably remembers, that that node has already been updated (which is strange, because if motion is defined with a function, there is no problem with any number of cycles (butterfly-flex example)). I'm pretty sure that there is no problem with the file being read (since if I remove the next cycle from the data, the meshing fails with negative volumes)
So, I think if I could reload the meshing udf at the end of the cycle somehow from inside the udf, this problem would be solved.
Leb is offline   Reply With Quote
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
