How define center of rotation for a 2D disk
Old   July 27, 2015, 10:18
Default How define center of rotation for a 2D disk
AhmadAli
a.ali is on a distinguished road
Hi
I'm trying to simulate a off center rotating 2D disk in a channel and I have problem. one send me an UDF and I compiled it but I could not change the center of rotation. here the UDF and problem geometry.
#include "udf.h"
static real v_prev = 0.0;
DEFINE_CG_MOTION(airfoil,dt,vel,omega,time,dtime)
real NV_VEC(A);
real dv;
/* reset velocities */
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
omega[2] = 10;
a.ali is offline   Reply With Quote
Old   October 29, 2016, 00:34
Wesley liu
luna125 is on a distinguished road
Originally Posted by a.ali View Post
Hi
#include "udf.h"
real NV_VEC(A);
real dv;
NV_S(vel, =, 0.0);
omega[2] = 10;
hi, guys,
did you solve the issue? i have the same issue about how to define a center of rotation since the rotation is off the center of gravity in fluent UDF.
luna125 is offline   Reply With Quote
Old   November 24, 2016, 03:42
Wesley liu
hi,
the fluent17.1 has dialogs to define the rotate center.
Old   December 31, 2017, 09:44
rjm1982 is on a distinguished road
Hello, I am also struggling with something similar. I am trying to have a 2D airfoil translating and rotating at the same time. The centre of rotation needs to be the 1/3rd chord of the airfoil, so the centre of rotation is moving at every time step due to the translation. I am trying to use DEFINE_CG_MOTION, but so far without success.
Does anyone know how I can specify the moving centre of rotation please?
rjm1982 is offline   Reply With Quote
Old   January 2, 2018, 05:28
Update: the centre of gravity dialogue boxes correspond to the initial values. These are updated automatically by Fluent. Therefore all you need to do is input the initial location of the centre of gravity/rotation and Fluent will update it automatically as the body moves!
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 22:13
UDF: trying to implement a Kinetic Equation source term er.mkumar Fluent UDF and Scheme Programming 35 March 22, 2019 11:20
SR_Rate UDF For a MEMs model timjm Fluent UDF and Scheme Programming 1 October 10, 2018 03:16
udf problem eb.nabizadeh Fluent UDF and Scheme Programming 2 March 1, 2013 01:28
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
