July 1, 2015, 01:39 |
UDF for Non-Newtonian power law fluids
Iman Sengupta
Rep Power: 11 |
I am working with CFD simulation of hydrocyclone. I want to incorporate non-Newtonian power law fluids. I used implicit VOF as multiphase flow model and RSM as turbulence model. For pressure I have used PRESTO and for momentum I have used QUICK. I have used SIMPLE to solve the problem. Is there any UDF for non-Newtonian power law fluids? Please help me.
July 14, 2015, 15:20 |
Casey
Rep Power: 17 |
Hi Iman - yes, you can make a UDF for a powerlaw fluid. You need to write the udf and then "hook" it into the viscosity (of the material). if you list the equation you want people can be of more help.
Power Law Velocity Profiled UDF | pwayne | STAR-CCM+ | 4 | May 12, 2014 20:10 |
udf for Power Profile | sarah l | Fluent UDF and Scheme Programming | 0 | August 16, 2013 18:05 |
power law code | majid reza mahjoob | FLUENT | 6 | June 12, 2012 00:25 |
Using UDF for setting velocity for two fluids | UDF user | FLUENT | 7 | November 26, 2008 07:22 |
power law fluid | ARAMESSH | Phoenics | 1 | October 4, 2002 09:57 |
