June 19, 2015, 06:54 |
#21 |
Martin
Rep Power: 11 |
What do you, that I some Howe should run the simulation all over again?
June 19, 2015, 07:04 |
#22 |
Rep Power: 27 |
If you find out that you did not simulate what you needed to simulate, then yes, you need to do it again.
But the good news is that steady-state is much faster than transient. I don't know why you did transient in the first place... |
June 19, 2015, 07:41 |
#23 |
Martin
Rep Power: 11 |
Its no purpose to run a LES simulation with steady state, off course I am simulating transient. Thank you Pakk but that is not a solution to my problem, it is much easier with UDF if I can get the script right
June 19, 2015, 08:32 |
#24 |
Rep Power: 27 |
If you think steady state LES has no purpose, then don't do it. You are free to spend a lot of computation time to get transient effects into your LES, and later on remove all those transient effects by making the time-average.
[edit: removed unnecessary details] What I am going to say now might make you angry, but be aware that is not my goal. To write code, you need to be accurate and patient, and I don't think you are sufficiently developed in those competences yet. This is all based on the little interaction I had with you in this thread, so I may be completely wrong, but otherwise I would advise you to avoid writing UDFs in the near future. |
June 19, 2015, 08:40 |
#25 |
Martin
Rep Power: 11 |
Yes you are right, No I really tried with the UDF manual, otherwise I could not have done this script even if it may be wrong. Its just that my simulations will take quite some time and I don't have the time to run those simulations again.
But I apologize if I was rude |
June 22, 2015, 04:56 |
#26 |
Rep Power: 27 |
No problem. I didn't feel you were rude, only inaccurate. Good luck!
write a UDF to give a velocity boundary condition at an interior face | Tharanga | Fluent UDF and Scheme Programming | 19 | August 5, 2018 05:29 |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 08:26 |
fluent udf problem: write specific data for every iteration in a file. | nnvoro | Fluent UDF and Scheme Programming | 1 | May 27, 2013 16:26 |
How to write UDF to achieve phase chang | dunga82 | Fluent UDF and Scheme Programming | 0 | May 6, 2013 09:50 |
how to write a 3D linear temperature of UDF | venus | FLUENT | 1 | October 28, 2008 03:46 |
