UDF error for variable Cp
Old   May 16, 2015, 20:16
Red face UDF error for variable Cp
Mohamed
B.Hamada is on a distinguished road
Hi all, I have written a UDF to a variable Cp, but when I interpreted it, an error appears on line 12:
line 12: exp: too many arguments supplied (argument 2)
My UDF:
HTML Code:
#include "udf.h"
DEFINE_SPECIFIC_HEAT(my_user_cp, T, Tref, h, yi)
real cp;
real delta=6;
real Tmelt=299.5;
real cps=1413;
real cpl=1797.6;
real lf=232;
if (T <= Tmelt)
cp = cps+lf*exp(-0,5*(T-Tmelt)*(T-Tmelt));
else if (T > Tmelt)
cp = cpl+lf*exp(-0,5*(T-Tmelt)*(T-Tmelt));
*h = cp*(T-Tref);
return cp;
So, please help me to rewrite it correctly!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:c onfused::c onfused:
B.Hamada is offline   Reply With Quote
Old   May 17, 2015, 16:27
Mohamed
PLeaaaaaaaaaaaaaaaaaaaaaaaaaaaaaase help meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Old   May 18, 2015, 05:43
upeksa is on a distinguished road
#include "udf.h"
real cp;
real delta=6;
real Tmelt=299.5;
real cps=1413;
real cpl=1797.6;
real lf=232;
if (T <= Tmelt)
cp = cps+lf*exp(-0.5*(T-Tmelt)*(T-Tmelt));
else if (T > Tmelt)/*no need if statement, "else" is enough*/
cp = cpl+lf*exp(-0.5*(T-Tmelt)*(T-Tmelt));
*h = cp*(T-Tref);
return cp;
upeksa is offline   Reply With Quote
Old   May 18, 2015, 06:14
pakk will become famous soon enough
Upkesa gives the right answer, I can give some more explanation.
You used:
In the c programming language, the symbol used for decimal notation is the dot (.) and not the comma (,). The comma is used to separate inputs. So your code was read as if the function "exp" was called with two arguments, one equal to "-0", and one equal to "5*(T-Tmelt)*(T-Tmelt)". But the function "exp" should only have one argument, so that is why the compiler gave the error message "too many arguments supplied".
pakk is offline   Reply With Quote
Old   May 18, 2015, 07:27
Red face
Mohamed
Originally Posted by upeksa View Post
#include "udf.h"
real cp;
real delta=6;
real Tmelt=299.5;
real cps=1413;
real cpl=1797.6;
real lf=232;
if (T <= Tmelt)
*h = cp*(T-Tref);
return cp;
You used:
Thank you very much for your help, it's really nice to give a hand to someone who needs a help. salam
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
