stops with no error
Old   May 12, 2015, 02:30
Default stops with no error
sarighulikhan
hane is on a distinguished road
dear friends
i have a question about fluent
i could successfully compile 2 mass transfer udfs and a udf for monod reaction eq.
these udfs can be either interperated or compiled and hooked without a small error
before compiling these udfs i run the steadystate simulation for the hydrodynamics of the problem
now i changed the solver to transient,compiled all 3 udfs ,hooked them
all these processes was without any error
but when i run the simulation in transient,the simulation in the first iteration after reservation of flow in the pressure out let stops,with out printing any error messege. it just stops and the cursor turns from processing mode to regular mode
do u know any solution to this problem?
regards
hane is offline   Reply With Quote
Old   May 12, 2015, 02:41
sarighulikhan
i might add that i solve the problem in parallel mode
i have parallelized my udf
any fresh idea?
Old   May 12, 2015, 04:57
pakk will become famous soon enough
Maybe a silly question, but did you set the number of time steps to be something bigger than zero?
pakk is offline   Reply With Quote
Old   May 12, 2015, 08:42
sarighulikhan
yes my friend,any other suggestions are appriciated
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
