May 6, 2015, 04:00 |
Negative volume detected
Mrinal K R
Rep Power: 15 |
Hi
The geometry is a circle which translate as well as rotate (attached fig). The circle is translating from center to both ends of the wall. A udf function used for dynamic mesh. But after some iteration negative cell volume detected because the circle reaching at the wall end (where the clearance is very less-0.185mm). Can anybody tell how to solve this problem? Last edited by MrinalKR; May 6, 2015 at 05:08. |
September 9, 2015, 01:18 |
Ahmed Jalal
Rep Power: 11 |
I get the same problem as I get closer to the walls. I am wondering whether it has something to do with the parameters of the meshing options.
Maybe check the numbers when setting the UDF for the Rigid body, in one of the tabs you can select cell height. Maybe that could help in solving the problem. |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 11:51 |
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 06:25 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 03:53 |
Negative volume Detected in Dynamic Mesh after 1500 time steps | abhinavgupta88 | Main CFD Forum | 2 | September 17, 2012 21:55 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
