May 3, 2015, 13:47 |
Error in Parallel
Rep Power: 13 |
After compiling udf in parallel mode, the error appeared in this manner. In fact, I changed the double to single precision as mentioned in another thread, still getting the same error. How to fix this?
Thanks in advance ================================================== ============================ Node 0: Process 9872: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 1: Process 6252: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 2: Process 3308: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 3: Process 2408: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 4: Process 6792: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 5: Process 9236: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 6: Process 3832: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 7: Process 9096: Received signal SIGSEGV. ================================================== ============================ MPI Application rank 0 exited before MPI_Finalize() with status 2 The fl process could not be started. |
May 3, 2015, 18:09 |
Rep Power: 18 |
Here's an answer about what the SIGSEGV errors represent. If you still can't make sense of your error, perhaps post your UDF code so that we can read it.
May 4, 2015, 00:02 |
Rep Power: 13 |
Thanks for the link. The error was due to memory allocation. In fact, after allocating the memory also the same error is displaying.
I am working on supersonic flow over a cylinder with sharp edged spike placed at front. from the below code, I am trying to visualize the pattern of shock wave and viscous effects in front of the cylinder. Here is the code. I am attaching the equation as well and the equation in attached file is for 1D flow, my case is 2D. Can you help me? Code:
#include "udf.h" #include "mem.h" #include "sg.h" #include "math.h" #define M_infi 1.2 #define a 340.26 DEFINE_ADJUST(sensors,d) { #if PARALLEL Thread *t; cell_t c; real f_shock, f_viscous; real first_term, second_term; real f_spurious; f_spurious=0; d=Get_Domain(1); thread_loop_c(t,d) { begin_c_loop(c,t) { first_term = ( - a / NV_MAG(C_P_G(c,t))) * ( (C_R(c,t) * C_U_G(c,t)[0]) + (C_U(c,t) * C_R_G(c,t)[0]) + (C_R(c,t) * C_V_G(c,t)[1]) + (C_V(c,t) * C_R_G(c,t)[1]) ); second_term = ( ( (C_U(c,t) * C_P_G(c,t)[0]) * (C_V(c,t) * C_P_G(c,t)[1]) ) * M_infi ) / ( ( sqrt( (C_U(c,t) * C_U(c,t)) + (C_V(c,t) * C_V(c,t)) ) ) * (NV_MAG(C_P_G(c,t))) ); f_shock = first_term + second_term; f_viscous = (C_MU_L(c,t)+C_MU_T(c,t)) / C_MU_L(c,t); if(f_shock>=1) { C_UDMI(c,t,0)=f_shock; } if(f_viscous>1.1) { C_UDMI(c,t,1)=f_viscous; } if((f_shock<1) && (f_viscous<=1.1)) { C_UDMI(c,t,2)=f_spurious; } } end_c_loop(c,t) } #endif } |
May 4, 2015, 01:26 |
Rep Power: 18 |
You've used three UDM spaces with the IDs 0, 1 and 2. Have you enabled three UDM slots?
May 4, 2015, 02:06 |
Rep Power: 13 |
Rep Power: 13 |
and still the error is same.
May 4, 2015, 03:28 |
Rep Power: 26 |
You use the pressure gradient, which might be removed from memory by Fluent.
Did you set "solve/set/expert", as mentioned in the Fluent manual section "3.2.3.7. Gradient (G) and Reconstruction Gradient (RG) Vector Macros"? |
May 4, 2015, 04:29 |
Rep Power: 13 |
I did that one also but still the error is same.
solve/set/expert use alternate formulation for wall temperatures? [yes] yes Keep temporary solver memory from being freed? [yes] yes Allow selection of all applicable discretization schemes? [yes] yes Explicit underrelaxation value: [0.75] 0.75 > iter continuity x-velocity y-velocity energy k omega Cl-1-cylinder Cd-1-cylinder time/iter Library "C:\xxx\ansys15\libudf\win64\2ddp_node\libudf. dll" opened ================================================== ============================ Node 0: Process 5284: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 1: Process 6200: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 2: Process 6284: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 3: Process 8388: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 4: Process 5924: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 5: Process 7144: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 6: Process 2692: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 7: Process 7544: Received signal SIGSEGV. ================================================== ============================ MPI Application rank 0 exited before MPI_Finalize() with status 2 The fl process could not be started. |
May 4, 2015, 04:32 |
#9 |
Rep Power: 26 |
Then I guess you need to really debug it in the hard way.
Add messages like "Code ran to here", to find out when your code gives errors. |
May 4, 2015, 08:48 |
#10 |
Rep Power: 13 |
Thank you
Ok.. May be.... I resolved that equation properly. Let me check it once again. I have a doubt in the above code, To find out the du/dx, this macro is correct right? C_U_G(c,t)... I used the same macro earlier but it had yielded compilation error "real[2] .....". After that I added C_U_G(c,t)[0] and did not yield any error. I feel like this may be the problem. |
May 4, 2015, 09:04 |
#11 | |
Rep Power: 26 |
C_U_G(c,t) is the gradient of the x-component of the velocity.This is a vector, so it has three components. The three components are dux/dx=C_U_G(c,t)[0], dux/dy=C_U_G(c,t)[1] and dux/dz=C_U_G(c,t)[2]. I don't know if that is the same as your "du/dx", because I don't know exactly what that is. I am not stupid, so of course I can see it is some derivative of some velocity, but the notation is exact enough to see if this is a scalar, a tensor or a vector. (Does it have 1 component, 3 or 9?) |
May 4, 2015, 09:36 |
#12 |
Rep Power: 13 |
I have just debugged the code and there is a problem in the first_term (code) statement.
In the first term of RHS of eqn, there is term (du/dx * rho) + (d(rho)/dx * u) The resultant term is the vector in this case because du/dx and d(rho)/dx are velocity gradient vector and density gradient vector respectively. Now can you explain this? |
May 4, 2015, 09:39 |
#13 |
Rep Power: 26 |
It seems to me that you have already explained that it is a vector. I don't understand what it is you would like me to explain.
May 6, 2015, 06:05 |
#14 |
Rep Power: 13 |
Thank you for the help. I deduced the whole equation into simple format and now fluent is working fine..
shiv |
Error running simpleFoam in parallel | Yuby | OpenFOAM Running, Solving & CFD | 14 | October 7, 2021 04:38 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
simpleFoam in parallel issue | plucas | OpenFOAM Running, Solving & CFD | 3 | July 17, 2013 11:30 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
