DPM : Solution for Collection Efficiency (just sharing)
Old   April 20, 2015, 06:36
Default DPM : Solution for Collection Efficiency (just sharing)
Manathan is on a distinguished road
This is a udf I've done to compute the collection efficiency in 2D planar case (for fun and pratice) ! So it doesn't work for axisymmetric flow. If anyone see any errors, I would be very happy to learn from them otherwise this post is just to help others.
WORKS FOR 2D ONLY : NOT AXISYMMETRIC !
#include "udf.h"
#include "dpm.h"
#include "surf.h"
#include "random.h"
#include "sg_mem.h"
#include "para.h"
#include "mem.h"
real beta[401] ;
real x[401] = { x } ; // x = value of the most frontal position of your wall impacted for y
real y[401] = { y } ;
real Vn[401];
real V0[401];
real x0[401] ;
real y0[401] ;
real dx[401] ;
real dy[401] ;
real dy0[401] ;
real norm2[401] ;
real ds[401];
int i = 1 ;
int n ;
DEFINE_DPM_BC(dpm_report,p,t,f,f_normal,dim)
Domain *domain; //Domain is declared as a variable
domain = Get_Domain(1); //Returns fluid domain pointer
double pwc[2], A[2], center[2];
double pt[2], B[2], centerb[2];
pwc[0] = P_POS(p)[0];
pwc[1] = P_POS(p)[1];
x[i] = pwc[0];
y[i] = pwc[1];
pt[0] = P_INIT_POS(p)[0] ;
pt[1] = P_INIT_POS(p)[1] ;
x0[i] = pt[0] ;
y0[i] = pt[1] ;
V0[i] = P_INIT_VEL(p)[0] ;
Vn[i] = NV_DOT(P_VEL(p), f_normal)/NV_MAG(f_normal) ;
dx[i] = x[i] - x[i-1] ;
dy[i] = y[i] - y[i-1] ;
dy0[i] = y0[i]-y0[i-1] ;
norm2[i] = pow( dx[i], 2) + pow(dy[i], 2) ;
ds[i] = pow(norm2[i], 0.5) ;
beta[i] = dy0[i]/ds[i] ;
i=i+1 ;
return x,y,x0,y0,dy0,ds,beta, PATH_ABORT;
DEFINE_ON_DEMAND(beta_profile)
FILE *f1;
f1 = fopen("report_beta.txt", "a");
fprintf(f1,"Stream Index, X impact, Y impact, x0, y0, dy, ds, beta\n");
for (i = 1 ; i <= 401 ; i++)
fprintf(f1, "%d %f %f %f %f %f %f %f\n", i-1,x[i],y[i],x0[i],y0[i],dy0[i],ds[i],beta[i] );
fclose(f1);
Manathan is offline   Reply With Quote
Old   April 21, 2015, 06:27
`e`
`e` is on a distinguished road
Firstly, thanks for sharing your code with the community and I have a couple of comments. First, if your goal is to count the number of particles to calculate the collection efficiency, you could use User-Defined Memory and increment face values for each particle deposition. Second, be careful with opening files with multiple nodes (processes) at the same time because you may corrupt or otherwise adversely affect your file; perhaps run this script on the host or on node 0 (these global variables are available to all processes).
`e` is offline   Reply With Quote
Old   April 21, 2015, 06:43
Thanks for your comments,
1) with the 2D approach, i just need to track the trajectory of particle and basically measure its deviation from injection : this is why i liked it, no need to work with face values, just need the DPM_BC function to get the "p" trapped at the wall.
But thank you for your approach, i previously didn't think of how to do it this way !
2) I'm not sure I understand the "multiple nodes" and the problem with this approach in term of files. I'm a junior in udf, fluent files etc...
Old   April 21, 2015, 07:12
`e`
I would have thought the UDM at boundary faces was the easier approach for measuring the collection efficiency (count the number of particles on a boundary face and compare with the injected particles). You could also visualise this deposition within ANSYS Fluent or ANSYS CFD-Post and export the values for post-processing elsewhere; however your resolution of results are restricted by your mesh.
However, if you're interested in the particle injection location and other parameters beyond the number of particles and particle mass fluxes then you'd need to store this data. I've used a similar approach where I saved this data directly to a text file within the DEFINE_DPM_BC macro and post-processed this data with MATLAB. This method has the benefit of not requiring a storage of large arrays in memory (millions of particles) and is easily tractable to arbitrary geometries and dimensions (no hard coding of arrays).
If you run ANSYS Fluent (or older versions of Fluent) in serial then your CPU essentially executes the commands in sequence; nice and straightforward. However, if you're running Fluent in parallel then some macros will be called by every node (core/thread/processor) you have allocated for Fluent (kind of; simply put) and others would only be called by one process.
DEFINE_ON_DEMAND is an example of a macro which is called by every node, host and in serial (have a read of the parallelisation of UDFs in the UDF Manual for details; it's a brief read). If one node, say NodeA, opens "report_beta.txt" and begins writing line by line the particle details but suddenly another node, say NodeB, has also been tasked with the same job and attempts to open the file then there could be issues (there is only one physical location on your HDD for this file). At the very least, if the C developers and/or Fluent developers have locked the file (not the case with fopen() etc), this writing process would take N times longer than serial where N is the number of nodes. On the other hand, the DEFINE_DPM_BC macro is only called by a single node when a particle collides with a boundary (each node essentially has a portion of all particles to "look after").
Old   April 21, 2015, 08:56
Thank you for your replies,
Everything is clearer now ! I will be careful with DEFINE_ON_DEMAND then...
So if i understand well; for my example about writing files, if I put those lines of DEFINE_ON_DEMAND simply in the DPM_BC macro, Will it do the job correctly and writing step by step at each impact the data in the file ? :
FILE *f1;
fprintf(f1, "%d %f %f %f %f %f %f %f\n", i-1,x,y,x0,y0,dy0,ds,beta );
fclose(f1);
Old   April 21, 2015, 09:19
`e`
If you write to one single file every time this DEFINE_DPM_BC is called then there's still a chance that two or more processes attempt to access this file (when two particles deposit at the same wall clock time). I've written to multiple files which are unique to each node using the "myid" variable (which is defined by Fluent, you don't declare or initialise this variable). For example:
FILE * f1;
char fileName[100];
sprintf(fileName, "deposited_particles_%d.dat", myid);
f1 = fopen(fileName,"a");
fclose(f1);
Then the first step of post-processing is to stitch these files together into one file or database for data analysis and visualisation.
Old   April 21, 2015, 09:22
ohhhhh ! that's an amazing trick oO, thank you so much !!!
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 22:22
Why 3D solid-pore geometry showing diverged solution? Sargam05 OpenFOAM 0 December 3, 2012 16:45
Analytic solution for 2D steady Euler equations jojo81 Main CFD Forum 0 October 15, 2012 13:05
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
