UDF for Velocity Inlet of Blood Flow
Old   April 15, 2015, 14:44
Default UDF for Velocity Inlet of Blood Flow
n_bowen is on a distinguished road
I am trying to run a simulation of blood flow with a user defined velocity inlet boundary condition.
Here is the udf that I use:
#include "udf.h"
#define PI 3.141592654
DEFINE_PROFILE(inlet_velocity, thread, index)
face_t f;
begin_f_loop(f, thread)
double t = (CURRENT_TIME*2-floor(CURRENT_TIME*2))/2;
if(t <= 0.218)
F_PROFILE(f, thread, index) = 0.5*sin(4*PI*(t+0.0160236));
else
F_PROFILE(f, thread, index) = 0.1;
end_f_loop(f, thread);
I get this error as I try to Interpret the function:
line 3: syntax error.
I am going through all example UDF files and cannot see what the problem is.
Thanks for your help.
n_bowen is offline   Reply With Quote
Old   April 16, 2015, 07:21
upeksa is on a distinguished road
#include "udf.h"
face_t f;
double t;
if(t <= 0.218)
F_PROFILE(f, thread, index) = 0.5*sin(4*M_PI()*(t+0.0160236));
else
upeksa is offline   Reply With Quote
Old   April 16, 2015, 14:18
Upeksa,
Thanks for your reply.
It looks like there is a problem with this line: DEFINE_PROFILE(inlet_velocity, thread, index)
since now that I have eliminated the line: #define PI 3.141592654
I'm getting the same error with a change in the line number:
line 2: syntax error
Old   April 17, 2015, 00:45
`e`
`e` is on a distinguished road
Try using the variable names they have provided in the UDF manual:
DEFINE_PROFILE(inlet_velocity, t, i)
Replace "thread" with "t" and replace "index" with "i". If this correction doesn't eliminate the syntax error, try using an example DEFINE_PROFILE macro to check you're interpreting/compiling and enabling the profile correctly.
`e` is offline   Reply With Quote
fluent - udf
UDF problems with porous flow Nicolastheterminator Fluent UDF and Scheme Programming 0 April 8, 2014 10:12
"Closing" a pressure inlet via UDF? dave88 Fluent UDF and Scheme Programming 0 August 27, 2013 19:14
Setting Inlet as Wall until flow occurs via UDF emmkell Fluent UDF and Scheme Programming 0 May 1, 2012 13:05
Velocity Inlet BC -- Flow Reversal salihovic FLUENT 0 May 8, 2011 06:45
udf for transient mass flow rate inlet mdzubairmanipal@gmail.com Fluent UDF and Scheme Programming 0 February 22, 2011 03:51
