April 7, 2015, 05:32 |
P_VEL(p)[i] Actual meaning?
Rep Power: 13 |
Wondering what this actually means P_VEL(p)[i], I was thinking it is an array of values of each of the velocity components (Tangential Radial Axial)?And are these the same as the (x y z) components? I think not not but just hoping for a nice explanation.
Anyhow, if it is one of the component systems from above, I found in the Fluent UDF manual for calculating the normal velocity the normal component is given in an array of 3 values as well. Shouldn't it be just a single value? Or am i misunderstanding this part of the code from the UDF manual: for(i=0; i<idim; i++) P_VEL(p)[i] -= vn*normal[i]; Thanks |
April 7, 2015, 06:12 |
Rep Power: 18 |
P_VEL(p)[i] is a macro returning velocities for a particle. P_VEL(p)[0] corresponds to the velocity in the x-direction, and so forth in Cartesian coordinates.
A vector, such as a (unit) normal vector, has several components as well so it makes sense to operate in each direction at a time (component-wise). |
April 7, 2015, 06:36 |
Rep Power: 13 |
How would you relate the velocities in the different Cartesian coordinates to the normal or tangential components? I thought that the components of P_VEL(p)[i] are the tangential, radial, axial components and each is equivalent to a direction (x,y,z).
Are you saying that the X velocity has further 3 components as well, that makes i a 3x3 matrix? Also in the above equation vn is the normal velocity, then why is it not written with its components like the other terms in the equation 'vn [i]'. Thanks |
April 7, 2015, 06:54 |
Rep Power: 18 |
Normal or tangential to what? Are you using Cartesian, cylindrical or other coordinates?
No. The particle has a motion in space and this velocity vector is the first time derivative of the displacement vector. In 3-D Cartesian coordinates: u=dx/dt, v=dy/dt and w=dz/dt. Or as vectors, u=dx/dt. For the particles in Fluent's DPM: u=P_VEL(p)[0], v=P_VEL(p)[1] and w=P_VEL(p)[2]. 'vn' is the magnitude of the normal velocity (perpendicular to the boundary face) and the normal unit vector is the variable 'normal' according to this post I assume you're referring to. Have a read of this Wikipedia article on the dot product operation. |
April 7, 2015, 09:43 |
Rep Power: 13 |
Thanks for that, I will go through it. Actually I dont even know what coordinates am i using, does it depend on the geometry? I suppose they are just cartesian, how do I tell?
April 7, 2015, 10:04 |
Rep Power: 18 |
You'll more than likely be using Cartesian coordinates, and that's fine (I'm not familiar with using other coordinate systems in Fluent and whether it's possible or practical to do so).
Who can tell me what is the meaning of the macro in fluent UDF:C_PREMIXC_RATE(c,t) | ChenZhan | Fluent UDF and Scheme Programming | 1 | May 12, 2017 04:40 |
What's meaning of UDF FUNCTION | zhaoxinyu | Fluent UDF and Scheme Programming | 0 | March 31, 2010 09:04 |
incompressible, The exact meaning of P in case/0/p ? | panda60 | OpenFOAM | 3 | December 2, 2009 05:41 |
Actual drag force from dimensionless equations | slaxmi | CFX | 10 | September 14, 2007 20:20 |
What's the meaning of "combustion scalar"and.... | cfdbeginner | CFX | 0 | November 27, 2003 10:02 |
