UDF to find Species mass fraction parallel Linux
Old   March 26, 2015, 06:53
Default UDF to find Species mass fraction parallel Linux
Schumacher00 is on a distinguished road
Hello Friends
would you please take a look at my Code.I'm confused, where the Problem is.
I receive a warning by the end of compiling " CC defined ,but not used" .I get by running Stack backtrace.
info: Linux/Parallel CPUs/ 3ddp
Thanks in advance
#include "udf.h"
#define BC_ID 5
#define nmrad 54
#define nmtang 2324
static double CC[nmtang*nmrad]={0.};
DEFINE_EXECUTE_AT_END(my_time_averager)
#if !RP_HOST
int mm;
double D[nmtang*nmrad];
double r[150000], tt[150000];
double R,tetha_prim,Y,Z;
FILE *fp;
fp = fopen("support-tat-blade1-outlet-Preparation.txt","r");
for (mm=0;(mm<nmtang*nmrad);mm ++)
fscanf(fp, "%lf %lf",&r[mm],&tt[mm]);
fclose(fp);
for (mm=0;(mm<nmrad);mm++)
r[nmtang*nmrad+mm]=r[mm];
tt[nmtang*nmrad+mm]=tt[mm];
for (mm=nmrad;(mm<nmrad*(nmtang+1));mm++)
r[mm-nmrad] =r[mm];
tt[mm-nmrad]=tt[mm];
fp= fopen("support-tat-blade1-outlet-Preparation.txt","w");
for (mm=0;(mm<nmtang*nmrad); mm++)
fprintf(fp, "%f\t %f\n", r[mm],tt[mm]);
fclose(fp);
double xx[ND_ND];
int numb = N_TIME;
Domain *d = Get_Domain(1);
Thread *t = Lookup_Thread(d,BC_ID), *tc;
face_t f;
Material *m;
int iair;
tc = THREAD_T0(t);
m = THREAD_MATERIAL(tc);
iair = mixture_specie_index(m,"air-2");
begin_f_loop(f,t)
F_CENTROID(xx,f,t);
Y=xx[1];
Z=xx[2];
R = sqrt(Y*Y+Z*Z);
tetha_prim = asin(-Z/R)/asin(1.)*90.;
if (Y<0.)
tetha_prim = tetha_prim/fabs(tetha_prim)*180.-tetha_prim;
for (mm=0;(mm<nmtang*nmrad);mm++)
if((fabs(R-r[mm])<0.00009) && (fabs(tetha_prim-tt[mm])<0.00009))
D[mm]=F_YI(f,t,iair); /* get the value of species air-2 */
CC[mm]=CC[mm]+D[mm];
end_f_loop(f,t)
if(numb==3)
fp = fopen("C-support-tat-blade1-outlet.txt","w");
for (mm=0;(mm<nmtang*nmrad);m++)
CC[mm]=(1/3)*CC[mm];
fprintf(fp, "%f\n", CC[mm]);
fclose(fp);
#endif
Schumacher00 is offline   Reply With Quote
Old   March 26, 2015, 06:57
`e`
`e` is on a distinguished road
What error message are you getting? Should your line saving to the text file be "C:\" instead of "C-"?
`e` is offline   Reply With Quote
Old   March 26, 2015, 07:02
Hi 'e'
Thanks for your quick response.
I get a warnning by compiling ' CC defined but not used'.By Running the calculation I get Stack backtrace .
Code gets compiled and loaded without any other Problem.
C- is just included by the name of the file,it's not an address.
Old   March 26, 2015, 08:56
pakk will become famous soon enough
If RP_HOST is set, the preprocessor reduces your code to:
static double CC[2324*54]={0.};
As you can see, in that case CC is defined, but never used.
pakk is offline   Reply With Quote
Old   March 26, 2015, 10:15
Thanks Pakk
So, I'm just not sure if I define static double CC[m*n] inside the EXECUTE macro, the calculated values for CC elements will be preserved at the end of each time step.
Moreover I have to exclude the Host CPU from Calculation task ,because I'm running fluent on parallel setting.
Right now, i just moved the defined static vaariable to below line of RP_HOST.Again Stack Backtrace...
What is the solution?
Old   March 26, 2015, 10:19
You want to have a solution, but you should first explain what the problem is.
Until now, you have only said that you see a warning when you compile. Is that a problem for you? In that case, make it
#if !RP_HOST
#endif
Or is something else than the warning the problem? You talk about "stack backtrace", but I have no idea what that is.
Old   March 26, 2015, 10:47
Stack backtrace generated for node id 0 (pid = 13244) on signal 11 :
Stack backtrace generated for node id 1 (pid = 13245) on signal 11 :
Stack backtrace generated for node id 5 (pid = 13249) on signal 11 :
Stack backtrace generated for node id 7 (pid = 13251) on signal 11 :
Stack backtrace generated for node id 3 (pid = 13247) on signal 11 :
Stack backtrace generated for node id 2 (pid = 13246) on signal 11 :
Stack backtrace generated for node id 6 (pid = 13250) on signal 11 :
Stack backtrace generated for node id 4 (pid = 13248) on signal 11 :
2: /lib64/libc.so.6() [0x3db1232920]
6: /lib64/libc.so.6(fscanf+0x88) [0x3db1262e08]
2: /lib64/libc.so.6(_IO_vfscanf+0x64) [0x3db12544c4]
6: libudf/lnamd64/3ddp_node/libudf.so(my_time_averager+0x5b) [0x7fe03bfb6ceb]
4: /--/--/--/fluent/1450/ansys_inc/v145/fluent/fluent14.5.0/lnamd64/3ddp_node/fluent_mpi.14.5.0() [0x1aedbfc]
Check the file fluenterror.log for details.
2: /lib64/libc.so.6(fscanf+0x88) [0x3db1262e08]
Please include this information with any bug report you file on this issue!
4: /lib64/libc.so.6() [0x3db1232920]
2: libudf/lnamd64/3ddp_node/libudf.so(my_time_averager+0x5b) [0x7f05dc83eceb]
4: /lib64/libc.so.6(_IO_vfscanf+0x64) [0x3db12544c4]
4: /lib64/libc.so.6(fscanf+0x88) [0x3db1262e08]
4: libudf/lnamd64/3ddp_node/libudf.so(my_time_averager+0x5b) [0x7f811d5bcceb]
3: /--/--/--/fluent/1450/ansys_inc/v145/fluent/fluent14.5.0/lnamd64/3ddp_node/fluent_mpi.14.5.0() [0x1ae9cc4]
3: /--/--/--/fluent/1450/ansys_inc/v145/fluent/fluent14.5.0/lnamd64/3ddp_node/fluent_mpi.14.5.0() [0x1aedbfc]
3: /lib64/libc.so.6() [0x3db1232920]
3: /lib6 The fluent process could not be started.
This error occures exatly by the execution of EXECUTE_AT_END. (end of the first time step)
Like I wrote ,I moved the lines but the same error apears.
1.I wrote out the .prof file to calculate the radial and angular coordinates of my Face Centrids.
2.Ordered them as my desired and saved as (support-tat... .txt).
3. in UDF defined Radius and angle just like the principle of my ordering in previous step to be calculated in begin/end_f_loop.
4. Now in Calculation if R(step3)==RR(Step2) && tetha(step3)==tetha(step2), do get the value of my "mass fraction of Specie " of that ceratin face.
5.Save the values of "mass fraction of specie" of all faces in CC array at the end(when times step number is for example 3).
Old   March 26, 2015, 10:56
Try to isolate the problem.
For example: put
Message("Code runs till point A.");
on several places in your code (replacing A by different letters of the alphabet.)
If you see on your screen:
Code runs till point B.
Code runs till point C.
(Fluent error)
Then the problem is between C and D.
how to load UDF in parallel at linux platform maye761 Fluent UDF and Scheme Programming 9 April 13, 2018 04:30
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 03:53
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
UDF for Species mass fraction daniel FLUENT 3 June 22, 2005 09:40
