Define dpm bc
Old   March 17, 2015, 06:06
Default Define dpm bc
Tao Ning
potatoning is on a distinguished road
I want to achieve the aim that the droplets are escape from a specified interface in the flow zone, and store the temperature and flow rate of droplets in UDM. the continuous phase flows as normal.
Can I use DEFINE_DPM_BC to do this?
pulling~my~hair~~
potatoning is offline   Reply With Quote
Old   March 17, 2015, 18:03
`e`
`e` is on a distinguished road
User-Defined Memory (UDM) is for either the cells or nodes within the domain (and is therefore generally used from the perspective of the continuous phase). You could have a UDM for accumulating the mass flow rate of droplets in cells at the boundary. As for the temperature, you could store the last droplet's temperature in a UDM in a similar way.
What exactly is your goal? Because if you're after a list of droplet temperature and flow rates after they have escaped the domain at this particular boundary, then simply save this data to a text file.
`e` is offline   Reply With Quote
Define steam flow rate belkadi OpenFOAM Programming & Development 0 June 27, 2013 08:24
UDF carbon conversion papteo Fluent UDF and Scheme Programming 1 August 18, 2011 08:32
DPM and UDS mighelone FLUENT 0 June 3, 2011 08:27
How to define injections in DPM model lingo FLUENT 5 December 16, 2003 11:22
Problem about DPM (how to define injections) lingo FLUENT 2 November 19, 2003 00:30
