March 15, 2015, 23:59 |
DEFINE_SOURCE reaction
Tleja
Rep Power: 13 |
Hello everyone!
I'm studying combustion reaction 2D. I'm really new in UDF field. At the moment,I wrote UDF about methane combustion reaction. Species in this system consist of N2,CH4,O2,CO2,H2O. As my UDF file, I have been trying to write UDF mass balance of each species for methane reaction. I could interpreted my UDF to fluent ,and I hooked my UDF to mass source of each specie like this file i attached. http://postimg.org/image/dilxz6uxh/ After that, I found the big problem that CO2 and H2O didn't generate in my system. I don't know why they didn't generate. Therefore, I also tried to simulate that system without UDF ,and then my new result was the same the old one . How can i solve this problem? i need to know why this new result is the same to the old one. My reaction is shown as below: CH4 + 2O2 ----k----> CO2 + 2H2O where k is function of temperature according to Arhenius law. My UDF was shown as below: Code:
#include "udf.h" #include "mem.h" #include "sg_mphase.h" #define PreKiM 2.119e11 /*unit m^3solid/kmol.s*/ #define Ea 2.027e8 /*unit kj/kmol*/ #define R 8.31434 /*Gas Constant J/mol-K*/ #define mw_n2 28.0134 /*kg/kmol*/ #define mw_ch4 16.04303 /*kg/kmol*/ #define mw_h2o 18.01534 /*kg/kmol*/ #define mw_co2 44.00995 /*kg/kmol*/ #define mw_o2 31.9988 /*kg/kmol*/ DEFINE_SOURCE(CH4_balance,c,tp,dS,eqn) /*kg/s.m^3 { real source; real KiM; real ch4,o2,co2,h2o; KiM=PreKiM*exp(-Ea/(R*C_T(c,tp))); /*Arhenius law*/ ch4=C_YI(c,tp,0)*C_R(c,tp)/mw_ch4; o2=C_YI(c,tp,1)*C_R(c,tp)/mw_o2; co2=C_YI(c,tp,2)*C_R(c,tp)/mw_co2; h2o=C_YI(c,tp,3)*C_R(c,tp)/mw_h2o; source=-KiM*mw_ch4*ch4*o2*o2; dS[eqn]=-KiM*(C_R(c,tp)/mw_ch4)*o2*o2; return source; } DEFINE_SOURCE(o2_balance,c,tp,dS,eqn) { real source; real KiM; real ch4,o2,co2,h2o; KiM=PreKiM*exp(-Ea/(R*C_T(c,tp))); ch4=C_YI(c,tp,0)*C_R(c,tp)/mw_ch4; o2=C_YI(c,tp,1)*C_R(c,tp)/mw_o2; co2=C_YI(c,tp,2)*C_R(c,tp)/mw_co2; h2o=C_YI(c,tp,3)*C_R(c,tp)/mw_h2o; source=-0.5*KiM*ch4*mw_o2*mw_o2*o2*o2; dS[eqn]=-*KiM*ch4*C_R(c,tp)/mw_o2; return source; } DEFINE_SOURCE(co2_balance,c,tp,dS,eqn) { real source; real KiM; real ch4,o2,co2,h2o; KiM=PreKiM*exp(-Ea/(R*C_T(c,tp))); ch4=C_YI(c,tp,0)*C_R(c,tp)/mw_ch4; o2=C_YI(c,tp,1)*C_R(c,tp)/mw_o2; co2=C_YI(c,tp,2)*C_R(c,tp)/mw_co2; h2o=C_YI(c,tp,3)*C_R(c,tp)/mw_h2o; source=KiM*mw_ch4*ch4*o2*o2; dS[eqn]=KiM*(C_R(c,tp)/mw_ch4)*o2*o2; return source; } DEFINE_SOURCE(h2o_balance,c,tp,dS,eqn) { real source; real KiM; real ch4,o2,co2,h2o; KiM=PreKiM*exp(-Ea/(R*C_T(c,tp))); ch4=C_YI(c,tp,0)*C_R(c,tp)/mw_ch4; o2=C_YI(c,tp,1)*C_R(c,tp)/mw_o2; co2=C_YI(c,tp,2)*C_R(c,tp)/mw_co2; h2o=C_YI(c,tp,3)*C_R(c,tp)/mw_h2o; source=0.5*KiM*ch4*mw_o2*mw_o2*o2*o2; dS[eqn]=KiM*ch4*C_R(c,tp)/mw_o2; return source; } Best regard Tleja Last edited by Tleja; April 4, 2015 at 02:34. |
March 16, 2015, 00:36 |
Rep Power: 18 |
Have you checked all the units and orders of magnitudes in those equations? Perhaps try setting a large arbitrary constant for the source terms to check if these UDFs are sending anything to the solver. If CO2 and H2O is then formed, perhaps the interaction is over a very long time frame (longer than you're currently running the simulations for), or the equations are incorrect. Also, try compiling the UDF instead of interpreting the source files.
March 16, 2015, 05:31 |
#3 | |
Tleja
Rep Power: 13 |
Thank you for your response,'e'
I already tried to simulate this system by using the same kinetic parameter in volume species transport reaction model without UDF. And, i could get the result from volume species transport reaction model. As my reaction, I simulated that system in steady-state approach. I guess if reaction is work, Product(H2O,CO2) should generate at least. According to your mention about increasing kinetic parameter, i already increased PreKiM from 2.119e11 to 2.119e20, the product didn't generate yet. I could interpreted this UDF code but i couldn't compile this code yet. When i compile, the error massage show as below Quote:
Please give me some idea Best regard Tleja |
March 16, 2015, 05:47 |
Rep Power: 18 |
The first thing is to ensure that Fluent can compile the UDF because if it can't, perhaps interpreting the UDF isn't doing much either. Have a read of the Fluent FAQ on compilers, I'm assuming you can't compile other UDFs either.
March 17, 2015, 23:20 |
Tleja
Rep Power: 13 |
Hi 'e'
I saw your advice. I tried to compile my UDF file to fluent At the moment, I have been able to compile my UDF to fluent. But my product(CO2,H2O) didn't generate yet. I don't know where the problem is Please give me some idea Best regard Tleja |
April 2, 2015, 13:26 |
Tleja
Rep Power: 13 |
Hi !!
According to my last response, I have solved compiling problem. At the moment, I can solve the last problem that is my product didn't generate by adjusting temperature at feed inlet from 300 to 1000. The product can little generate. Actually, the real system shouldn't operate at this temperature i defined. I think i should include energy source (heat of reaction) UDF to this case. In my understanding, Heat of reaction = rate of reaction*(summation Enthalpy of product- summation enthalpy of reactant) I have been trying to write UDF. But, It didn't work yet. My product generation don't make sense like this http://postimg.org/image/99rsab0lv I tried to operate this reaction by using the built-in volumetric reaction feature in fluent. The product generation is ok like this http://postimg.org/image/mtzp2keft I think if my source UDF file is work, it should be similar to another one. I have no idea why the result from my UDF source is totally different to using the built-in volumetric reaction feature. The last UDF version is shown as below: Code:
#include "udf.h" #include "mem.h" #include "sg_mphase.h" #define PreKiM 2.119e11 /*unit m^3solid/kmol.s*/ #define Ea 2.027e8 /*unit kj/kmol*/ #define R 8.31434 /*Gas Constant J/mol-K*/ #define mw_n2 28.0134 /*kg/kmol*/ #define mw_ch4 16.04303 /*kg/kmol*/ #define mw_h2o 18.01534 /*kg/kmol*/ #define mw_co2 44.00995 /*kg/kmol*/ #define mw_o2 31.9988 /*kg/kmol*/ #define Hch4 -7.489518e4 /*kj/kmol*/ #define Ho2 0 /*kj/kmol*/ #define Hco2 -3.935324e5 /*kj/kmol*/ #define Hh2o -2.418379e5 /*kj/kmol*/ DEFINE_SOURCE(CH4_balance,c,tp,dS,eqn) { real source; real KiM; real ch4,o2,co2,h2o; KiM=PreKiM*exp(-Ea/(R*C_T(c,tp))); ch4=C_YI(c,tp,0)*C_R(c,tp)/mw_ch4; o2=C_YI(c,tp,1)*C_R(c,tp)/mw_o2; co2=C_YI(c,tp,2)*C_R(c,tp)/mw_co2; h2o=C_YI(c,tp,3)*C_R(c,tp)/mw_h2o; source=-KiM*mw_ch4*ch4*o2*o2; dS[eqn]=-KiM*(C_R(c,tp)/mw_ch4)*o2*o2; return source; } DEFINE_SOURCE(o2_balance,c,tp,dS,eqn) { real source; real KiM; real ch4,o2,co2,h2o; KiM=PreKiM*exp(-Ea/(R*C_T(c,tp))); ch4=C_YI(c,tp,0)*C_R(c,tp)/mw_ch4; o2=C_YI(c,tp,1)*C_R(c,tp)/mw_o2; co2=C_YI(c,tp,2)*C_R(c,tp)/mw_co2; h2o=C_YI(c,tp,3)*C_R(c,tp)/mw_h2o; source=-0.5*KiM*ch4*mw_o2*mw_o2*o2*o2; dS[eqn]=-KiM*ch4*o2*C_R(c,tp)/mw_o2; return source; } DEFINE_SOURCE(co2_balance,c,tp,dS,eqn) { real source; real KiM; real ch4,o2,co2,h2o; KiM=PreKiM*exp(-Ea/(R*C_T(c,tp))); ch4=C_YI(c,tp,0)*C_R(c,tp)/mw_ch4; o2=C_YI(c,tp,1)*C_R(c,tp)/mw_o2; co2=C_YI(c,tp,2)*C_R(c,tp)/mw_co2; h2o=C_YI(c,tp,3)*C_R(c,tp)/mw_h2o; source=KiM*mw_ch4*ch4*o2*o2; dS[eqn]=0; return source; } DEFINE_SOURCE(h2o_balance,c,tp,dS,eqn) { real source; real KiM; real ch4,o2,co2,h2o; KiM=PreKiM*exp(-Ea/(R*C_T(c,tp))); ch4=C_YI(c,tp,0)*C_R(c,tp)/mw_ch4; o2=C_YI(c,tp,1)*C_R(c,tp)/mw_o2; co2=C_YI(c,tp,2)*C_R(c,tp)/mw_co2; h2o=C_YI(c,tp,3)*C_R(c,tp)/mw_h2o; source=0.5*KiM*ch4*mw_o2*mw_o2*o2*o2; dS[eqn]=0; return source; } DEFINE_SOURCE(HXR,c,tp,dS,eqn) { real source; real KiM; real delH,ch4,o2,co2,h2o; KiM=PreKiM*exp(-Ea/(R*C_T(c,tp))); ch4=C_YI(c,tp,0)*C_R(c,tp)/mw_ch4; /*kmol/m3*/ o2=C_YI(c,tp,1)*C_R(c,tp)/mw_o2; co2=C_YI(c,tp,2)*C_R(c,tp)/mw_co2; h2o=C_YI(c,tp,3)*C_R(c,tp)/mw_h2o; delH=(2*Hh2o+Hco2-Hch4); /*kj/kmol*/ source=KiM*ch4*o2*o2*delH; /*kj/m3s*/ dS[eqn]=0; return source; } Best Regard Tleja |
PaSR + infinite reaction rate in reactingFoam --> no reactions occurring | tatu | OpenFOAM Running, Solving & CFD | 3 | June 2, 2024 11:04 |
Having problems setting up surface reaction, catalyst, adsorption and desorption | Juun | FLUENT | 12 | February 8, 2017 12:03 |
Defining reaction rate with multiple surface reaction | Fred Marias | FLUENT | 1 | September 12, 2013 05:56 |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 17:55 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 01:07 |
