problem with mixed/Robin boundary condition for Temperature
Old   March 8, 2015, 15:03
Default problem with mixed/Robin boundary condition for Temperature
Jing
serene6390 is on a distinguished road
Hi, all
I'm trying to build a mixed boundary condition for temperature profile, the boundary condition is an expression related to both Temperature and Temperature gradient, but there's some error come out after I initialize.
My code is:
DEFINE_PROFILE(Temperature_profile,t,i)
face_t f;
cell_t c;
Thread*t0;
real x[ND_ND];
real y;
begin_f_loop(f,t)
t0=THREAD_T0(t);
c=F_C0(f,t);
F_CENTROID(x,f,t);
y=x[1];
F_PROFILE(f,t,i)=(200-20*(1-y)+C_T_G(c,t0)[0]/0.002)/(100+9.8*(1-y);
end_f_loop(f,t)
My current physical model is very simple, just a 2D rectangular area.
Thank you so much.
PS: I don't know why but the program sometimes works and sometimes not, but even if it could run successfully, the result seems not correct.
The error looks like this:
MPI Application rank 0 exited before MPI_Finalize() with status 2
The f1 process could not started
serene6390 is offline   Reply With Quote
Old   March 8, 2015, 15:46
`e`
`e` is on a distinguished road
Here's a relevant thread and have you tried running Fluent in serial instead of parallel?
`e` is offline   Reply With Quote
Old   March 8, 2015, 16:23
Jing
Thanks for your reply, but when I try to use serial instead of parallel, there's another error comes out:
Error: received a fatal signal (segmentation fault)
Old   March 8, 2015, 19:20
`e`
Have you interpreted or compiled the UDF? Try compiling the UDF.
Ensure the RHS for F_PROFILE is correct and use trailing periods to evaluate 200, etc, as real data types.
Lastly, try setting the RHS of F_PROFILE to a constant value and if this run still fails, then perhaps there's something wrong with the mesh (maybe Fluent is trying to access a cell face that doesn't exist).
Old   March 8, 2015, 23:17
Jing
I interpreted the UDF, is compiling going to make a difference?
I'm thinking the error might caused by the index, do you think it's correct that on the LHS I have F_PROFILE(f,t,i) and on the RHS I have C_T_G(c,to)[0]?
Thank you.
Old   March 9, 2015, 00:04
`e`
When troubleshooting code it's important to first isolate what the problem exactly; you can achieve this task by building the program step by step (or removing/simplifying your code step by step). I've suggested a method of trying to isolate the problem code above.
Old   March 9, 2015, 00:19
Jing
Sorry that I didn't mention that I've tried setting the RHS as constant and it works. I also tried making the RHS as 1-y, it also works well.
Old   March 9, 2015, 00:26
`e`
It appears that gradient data may or may not be defined in the first iteration according to HenrikS in this post (try his suggestion).
gradient, mixed boundary condition, temperature profile, udf
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 29, 2010 00:32
How to use a solution as an inlet boundary condition in another problem in fluent geryes FLUENT 0 February 25, 2010 17:32
a problem with Boundary condition M Rad Main CFD Forum 12 November 27, 1998 13:49
