How to give Parabolic profile at the inlet of a pipe using UDF(User Defined Function) |
March 4, 2015, 13:11 |
KARTHIK GS
Rep Power: 11 |
Hey everyone...
I am working on a problem associated with flow through pipes with orifice plate. I want to establish a parabolic flow nature or a much flatter profile depending on laminar or turbulent flows, at the entrance of the pipe which contains orifice plate. Can anyone explain or guide me how to do it ? A tutorial file would be very helpful. Thank you |
March 5, 2015, 05:15 |
Rep Power: 27 |
Did you even search anywhere before you post this message???
Seriously... 1. When you posted this message, one of the recent thread names was "SOS.udf inlet parabolic velocity for aerodynamic analysis". That is almost exactly what you also ask... 2. If I type in the Fluent help "parabolic inlet", the second result is a detailed explanation of how to write a udf for a parabolic inlet. 3. If I type in Google "parabolic inlet udf", I get many, many results that point to an example of a udf for a parabolic inlet. Please don't see this as an attack, so you don't need to defend yourself. I am honestly curious to know. Why didn't you do these searches yourself? Or did you do them, but found them not suitable? If so, why didn't you at least mention that in your question? |
March 5, 2015, 07:32 |
KARTHIK GS
Rep Power: 11 |
Sir i searched it before posting it. May be i dint put efforts. I couldn't understand so i decided to post this here so that anyone could give me direct instructions. Also i am new to these on-line forums. I will definitely improve myself next time sir. I will look up for solutions wherever you have mentioned and i will learn it by myself. Thank you for your valuable reply sir. It means a lot to me.
March 5, 2015, 07:36 |
Rep Power: 27 |
Okay. Tip: if you have already found something but could not understand that, mention that. Then people at least know that they don't have to point you to that result.
But the results that I talk about, have step-by-step instructions. What more do you want? |
March 5, 2015, 07:49 |
KARTHIK GS
Rep Power: 11 |
I found the fluent help file now. I will go through it and do according to the procedure. Its under the heading "Define Profile" in the Fluent UDF Manual. I just found it now. Thank you sir..
orifice plate, parabolic inlet, turbulent inlet, udf, udf and programming |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 11:20 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 07:27 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
