March 4, 2015, 08:37 |
DYNAMIC MESH udf for orbiting motion.
Avinash Dash
Rep Power: 11 |
I am trying to write an UDF for orbiting motion eg as in this picture in the dynamic mesh method
motion.gif the body(square) has no omega of its own, but it is translating in a circle of radius (say 10 cm ) with some angular velocity ( say 1 rad/sec). |
March 4, 2015, 08:40 |
Avinash Dash
Rep Power: 11 |
will appreciate any help...
March 4, 2015, 10:00 |
Rep Power: 27 |
Start with an empty text file, look in the Fluent help for which functions you can use, and just try something. If you think you have something reasonable, try to compile it and test it. If it does not work, and you need help, post your attempt here and I am sure you will get some advice. Good luck!
March 4, 2015, 11:58 |
Avinash Dash
Rep Power: 11 |
Thanks for the interesting reply.
Here is what i know. The following macro is used to define the zone motion " DEFINE_CG_MOTION (name, dt, vel, omega, time, dtime) " where vel & omega are linear & angular velocity of the zone (assuming it to be a rigid body). But in an orbiting motion the body itself has no omega, but is translating in a circular motion with some angular velocity. I haven't been able to figure out how to give the CG (centre of gravity) an angular velocity about the global frame of reference. PS : defining velocity of CG as V-x_component = V*sin(wt) & V-x_component = V*cos(wt) isn't a very acurate way. |
UDF for Dynamic Mesh | vasava | Fluent UDF and Scheme Programming | 2 | September 25, 2013 01:54 |
udf dynamic mesh | hillat | Fluent UDF and Scheme Programming | 1 | February 10, 2013 20:00 |
Dynamic Mesh UDF | Jkl | FLUENT | 9 | September 7, 2011 00:43 |
UDF, dynamic mesh motion | phil | FLUENT | 0 | September 15, 2004 06:42 |
Problem related with UDF for dynamic mesh | Ryan | FLUENT | 6 | April 29, 2004 10:29 |
