New to UDF
Like Tree7Likes
Old   April 7, 2015, 03:15
Exclamation
  #61
shivakumar is on a distinguished road
After several iterations as well as on demand execution once again the error occurred.
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
shivakumar is offline   Reply With Quote
Old   April 7, 2015, 04:05
`e`
`e` is on a distinguished road
What's your latest version of the UDF, does my reply below still apply?
Originally Posted by `e` View Post
The fatal error, "ACCESS_VIOLATION", may suggest that you're trying to access a variable that doesn't exist. I've read that the gradients are not evaluated for the first iteration and only exist from the second iteration onward. You're calling C_P_G from the start of the first iteration (before the solver is called), run the UDF after the first iteration (or set C_P_G to zero/otherwise for the first iteration).
`e` is offline   Reply With Quote
Old   April 7, 2015, 04:41
Unhappy
  #63
#include "udf.h"
#include "mem.h"
#include "sg.h"
#include "math.h"
#define gamma 1.4
#define temp_infi 288.15
#define rho_infi 1.225064
#define pre_infi 101325
#define u_infi 248.0514708
#define R 287
#define M_infi 0.729
#define a 340.26
DEFINE_ON_DEMAND(shock_viscous)
	Domain *d;
	Thread *t;
	cell_t c;
	real aa,bb,del_dot_F;
	real f_shock, f_viscous;
	real d_wave,d_viscous, d_spurious;
	d=Get_Domain(1);
	d_wave=0;
	d_viscous=0;
	d_spurious=0;
	thread_loop_c(t,d)
		begin_c_loop(c,t)
			C_P_G(c,t)[0]=1;
			aa=log((C_P(c,t)/pre_infi)*pow((rho_infi/C_R(c,t)),gamma));
			bb=(C_R(c,t)*u_infi*aa)/(gamma*M_infi*M_infi*(gamma-1));
			del_dot_F=bb*(C_DUDX(c,t)+C_DVDY(c,t)+C_DWDZ(c,t));
			f_shock=((C_U(c,t)*C_P_G(c,t)[0]) + (C_V(c,t)*C_P_G(c,t)[1]) + (C_W(c,t)*C_P_G(c,t)[2]))/(a*(NV_MAG(C_P_G(c,t))));
			f_viscous= (C_MU_L(c,t)+C_MU_T(c,t))/C_MU_L(c,t);
			if(f_shock>=1)
				d_wave+=del_dot_F;
				C_UDMI(c,t,1)=f_shock;
			if(f_viscous>(1.1*f_viscous))
				d_viscous+=del_dot_F;
				C_UDMI(c,t,1)=f_viscous;
			if(f_shock<1 && f_viscous<=(1.1*f_viscous))
				d_spurious+=del_dot_F;
				C_UDMI(c,t,1)=d_spurious;
		end_c_loop(c,t)
	printf("The Viscous drag = %g\n",d_viscous);
	printf("The wave drag= %g\n", d_viscous);
	printf(" The spurious drag = %g\n",d_spurious);
Thanks for the reply.
It had run for 5000 iterations.. Finally the error..
I applied the same still getting the access_violation error.
Old   April 7, 2015, 07:37
`e`
Why have you included this line of code?
C_P_G(c,t)[0]=1;
You're setting the cell's pressure gradient in the x-direction to unity every time...
As for the "ACCESS_VIOLATION" error, you'll need to determine which line of code is causing this error. Insert print to screen commands such as Message0("Here is the beginning of the cell loop\n"); to debug your code.
shivakumar likes this.
Old   April 8, 2015, 01:52
After inserting the Message in code.
#include "udf.h"
#include "mem.h"
#include "sg.h"
#include "math.h"
#define gamma 1.4
#define R 287
#define a 340.26
	Domain *d;
	Thread *t;
	cell_t c;
	d=Get_Domain(1);
	d_wave=0;
	d_viscous=0;
	d_spurious=0;
	Message("point a\n");
	thread_loop_c(t,d)
		begin_c_loop(c,t)
			Message(" point 1 \n");
			Message(" point 2 \n");
			if(f_shock>=1)
				Message("point 3\n");
				Message("point 4\n");
				Message("point 5\n");
				d_wave+=del_dot_F;
				Message("point 6\n");
				Message("point 7\n");
			Message("point 8\n");
				Message("point 9\n");
				Message("point 10\n");
				Message("point 11\n");
				Message("point 12\n");
				Message("point 13\n");
			Message("point 14\n");
				Message("point 15\n");
				Message("point 16\n");
				Message("point 17\n");
				Message("point 18\n");
				Message("point 19\n");
		end_c_loop(c,t)
The following output with error has occurred.
point a
 point 1
 point 2
point 9
point 10
Error:
Error Object: #f
Old   April 8, 2015, 02:22
`e`
Firstly, be careful where you add lines of code for example:
Message("point 8\n"); // this line of code is executed only if the above condition is satisfied
    // this section of code is always executed, regardless of the above if statement
From your detailed use of the Message() function, we can see the problem line is:
What are you trying to calculate here (what is the equation)? Could you instead use C_STRAIN_RATE_MAG as suggested by coglione?
Old   April 8, 2015, 02:55
This is eqn of force obtained without multiplying velocity vector.
del_dot_F is divergence of force.
when I multiplied bb with the velocity vector. I got
(du/dx + dv/dx+ dw/dz)*bb..
This is what I was expecting from the below line.
Old   April 8, 2015, 04:12
`e`
Check if Fluent can access the local cell velocity with the same cell number and thread pointer in the same area of code:
Message("C_U(c,t) = %e\n",C_U(c,t));
Message("C_DUDX(c,t) = %e\n",C_DUDX(c,t));
Old   April 8, 2015, 04:59
Exclamation
  #69
thanks for the reply.. It is accessing those values..
Here is the code
#include "udf.h"
#include "mem.h"
#include "sg.h"
#include "math.h"
#define gamma 1.4
#define R 287
#define a 340.26
	Domain *d;
	Thread *t;
	cell_t c;
	d=Get_Domain(1);
	d_wave=0;
	d_viscous=0;
	d_spurious=0;
	thread_loop_c(t,d)
		begin_c_loop(c,t)
			if(f_shock>=1)
				d_wave+=del_dot_F;
		end_c_loop(c,t)
Error reads
point a
 point 1
 point 2
point 9
point 10
C_U(c,t) = 2.293790e+02
C_DUDX(c,t) = 3.646992e+02
Error:
Error Object: #f
Old   April 8, 2015, 05:07
`e`
What about C_DWDZ(c,t)? If you're running 2-D then it'd make sense if that variable wasn't available because it's only available in 3-D.
Old   April 8, 2015, 05:24
Sorry I forgot to inform its 2D. I need the same in 3D as well.
I just changed the code now. Its running like anything, cannot stop the fluent. I just clicked execute on demand. Its not giving access_violation error. its executing. I dunno when it will stop.
Can you check this code? Is it correct?
#include "udf.h"
#include "mem.h"
#include "sg.h"
#include "math.h"
#define gamma 1.4
#define R 287
#define a 340.26
	Domain *d;
	Thread *t;
	cell_t c;
	d=Get_Domain(1);
	d_wave=0;
	d_viscous=0;
	d_spurious=0;
	thread_loop_c(t,d)
		begin_c_loop(c,t)
			f_shock=((C_U(c,t)*C_P_G(c,t)[0]) + (C_V(c,t)*C_P_G(c,t)[1]))/(a*(NV_MAG(C_P_G(c,t))));
			if(f_shock>=1)
				del_dot_F=bb*(C_DUDX(c,t)+C_DVDY(c,t));
				d_wave+=del_dot_F;
		end_c_loop(c,t)
Old   April 8, 2015, 05:37
Smile
  #72
Thank you so much 'e'...
Its executing each and every messages now....
Old   April 8, 2015, 05:42
`e`
Great, so the issue was you were trying to access a gradient, dw/dz, which is only applicable in 3-D cases but you're running a 2-D case. Remember that you'll need to include these z-direction forces/gradients for your 3-D case.
Old   April 8, 2015, 05:53
Ok 'e'. I will keep in mind. thank you.
I just run the fluent for 60 iterations and it didnt give any access violation errors.
Output looks like this.
The Viscous drag = 0
The wave drag= 0
 The spurious drag = -1.#IND
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
