Turbulent Interactions UDF in Eulerian
Old   February 22, 2015, 22:12
Question Turbulent Interactions UDF in Eulerian
guhard is on a distinguished road
So I am working on a project at the UNI.
I was told to simulate the turbulent interaction by modifying sources in K and epsilon equations. I am using Eulerian model with Per phase turbulence model. The source is of following equation
PI_k = 4/3 * C_d * rho_c *alpha / d_b *|U_r|^3
where:
  • C_d - drag coefficient,
  • rho_c - density of continuous phase - water
  • d_b - bubble diameter - of air - I use C_PHASE_DIAMETER for it,
  • U_r - relative velocity
Unfortunately I dont have much information about that model for turbulent interactions, hopefully, that won't be so important.
Anyway, I wrote this udf:
DEFINE_SOURCE(PI_E_wat, cell, phase_t, dS, eqn)
    Thread *mt;
    Thread **all_phase_t;
    Thread *thread_c, *thread_d;
    const real c1 = 3.0;
    const real c2 = 4.0;
    const real g_force = 9.81;
    real C_drag, Re_b, U_rel_x, U_rel_y, U_rel, U_r;
    real rho_c, rho_d, delta_rho, alpha_d, PI_k, PI_E;
    mt = THREAD_SUPER_THREAD(phase_t);
    all_phase_t = THREAD_SUB_THREADS(mt);
    thread_c = all_phase_t[0];  /*THREAD_SUB_THREAD(mix_thread, WATER_ID);  liquid phase */
    thread_d = all_phase_t[1];  /*THREAD_SUB_THREAD(mix_thread, AIR_ID);  gas phase */
    U_rel_x = C_U(cell, thread_d) - C_U(cell, thread_c);
    U_rel_y = C_V(cell, thread_d) - C_V(cell, thread_c);
    U_r = sqrt(U_rel_x*U_rel_x + U_rel_y*U_rel_y); /* relative velocity from udf */
    real d = C_PHASE_DIAMETER(cell, thread_d);
    alpha_d = C_VOF(cell, thread_d);
    rho_c = C_R(cell, thread_c);  /* water density */
    rho_d = C_R(cell, thread_d); /* air density */
    delta_rho = rho_c - rho_d; /* delta rho */
    Re_b = rho_c * fabs(U_rel) * d / C_MU_L(cell, thread_c);  /* Reynolds number with relative velocity*/
    C_drag = 24 / Re_b*(1 + 0.15*pow(Re_b, 0.687)); /* Drag coefficient */
    PI_k = 3.0 / 4.0*C_drag*rho_c*alpha_d / d*pow(fabs(U_r), 3);
    PI_E = 1.2 * C_D(cell, phase_t) / C_K(cell, phase_t) * PI_k;
    dS[eqn] = 0;
    return PI_E / 2;
Since the original model is not k dependent I assumed dS[eqn] = 0. Unluckily, I am afraid this is causing covergence problems.
Without the UDF i was able to run multiphase simulation with all possible 2-phase interaction in fluent, with Coupled pressure-velocity scheme and solution converged for steady state(good job me).
Whenever I include (accordingly written) sources for both phases and turbulent equations, I see this
iter  continuity     u-water       u-air     v-water       v-air     k-water       k-air   eps-water     eps-air         iac      vf-air     time/iter
# Divergence detected in AMG solver: k -> Decreasing coarsening group size!
# Divergence detected in AMG solver: k -> Increasing relaxation sweeps!
# Divergence detected in AMG solver: pressure correction -> Turning off correction scaling!
# Divergence detected in AMG solver: pressure correction -> Increasing relaxation sweeps!
Error: Divergence detected in AMG solver: pressure correction
Error Object: #f
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate
Error Object: #f
I have no idea what I can do.
From other posts I learned that lower URF, or "coarsening" my mesh might help, so far, nothing works.
Can't wait for your suggestions, pointing out my mistakes or in general pointing the direction I should take.
Regards,
Michal
guhard is offline   Reply With Quote
Old   February 23, 2015, 13:04
Solved the problem, thread can be deleted.
Old   February 24, 2015, 04:14
pakk will become famous soon enough
Good for you! It could be helpful if you give the solution to your problem in a few words, for if somebody else has a similar problem in the future.
pakk is offline   Reply With Quote
Old   February 24, 2015, 12:02
Sure, although it wasn't really "fluent related".
In my formula for Reynolds I used "U_rel", but the relative velocity was assigned "U_r". As a result, Re_b became 0, thus drag coefficient became infinite.
The moral of this story is if you see error as I saw, check your variables names
Old   November 12, 2018, 03:57
Default define the thread
Dali You
daliyou is on a distinguished road
Hello guys,
I would like to define a two phase threads and calculate the relative velocity as you post, while it always appear erros.
I tried to fix the problem line by line. I found the problem is the line 'thread_c = all_phase_t[0]'
The code is as following:
#include "udf.h"
#include "sg.h"
#include "sg_mphase.h"
#include "flow.h"
#include "mem.h"
#include "metric.h"
/* ************************** Memory and scalar description **************** *\
UDM-0: Gb
DEFINE_SOURCE(Gb, c, phase_t, dS, eqn)
real Cb, U_rel_x, U_rel_y, U_rel, U_r, source;
real rho_c, rho_d, delta_rho;
Thread *thread_c,*thread_d,*mt;
Thread **all_phase_t; /*array*/
mt=THREAD_SUPER_THREAD(phase_t);
all_phase_t=THREAD_SUB_THREADS(mt);
thread_c = all_phase_t[0];/*THREAD_SUB_THREAD(mt, 1); THREAD_SUB_THREAD(mix_thread, WATER_ID); liquid phase */
U_rel_x = C_U(c, thread_d) - C_U(c, thread_c);
U_rel_y = C_V(c, thread_d) - C_V(c, thread_c);
/* U_r=sqrt(pow(U_rel_x,2.0)+pow(U_rel_y,2.0))*/
Cb= 0.8;
rho_c = C_R(c, thread_c); /* water density */
rho_d = C_R(c, thread_d); /* air density */
source= Cb*C_MU_L(c,phase_t)/C_MU_EFF(c,phase_t)*delta_rho*g_force*C_VOF(c,phas e_t)*U_r;*/
dS[eqn]= 0.0;
return source;
The error message:
999999 (..\src\mpsystem.c@1172): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument
MPI Application rank 0 exited before MPI_Finalize() with status -1073741819
The fl process could not be started.
Thanks for your reading and help!
Best regards
Dali
daliyou is offline   Reply With Quote
amg solver, multiphase, pressure correction, udf
Eulerian multiphase model for species trnasport: UDF for reaction rate harsh Main CFD Forum 3 June 12, 2017 03:24
UDF for fully developed turbulent flow at inlet soroushsaberi FLUENT 0 May 28, 2014 18:00
UDF for 3D turbulent fully developed flow howhs Fluent UDF and Scheme Programming 0 August 1, 2013 12:47
UDF - PDF for turbulent reaction calculations ronen Fluent UDF and Scheme Programming 5 July 10, 2013 11:31
UDF for fully developed turbulent pipe flow Maged FLUENT 1 June 11, 2005 11:37
