UDf for condensation
Old   January 19, 2015, 12:53
Exclamation UDf for condensation
anonymous
farr24 is on a distinguished road
hi, I recently started using UDF and I have a lot of problems if someone can help me.
I have to create a UDF which will allow me to inject a heat source based on different parameters.the UDF that I create is this,
#include "udf.h"
DEFINE_heat(inlet_x_heat,thread)
real temp,volume,area,heat,alfv,NV_VEC(A);
real rhov = 999.6;
real rconst = 0.1;
real hfg = 2500;
real T_SAT = 18;
real x = 0.0132;
Thread *t;
cell_t c;
face_t f;
alfv= x/(0.622+x);
begin_c_loop(c,t)
temp = C_T(c,t);
if (temp > T_SAT)
{ heat = 0;}
else if(temp < T_SAT)
{ volume = C_VOLUME(c,t);
F_AREA(A,f,t);
area = NV_MAG(A);
area += NV_MAG(A);
heat =(rconst*alfv*rhov*(T_SAT-temp)*hfg*volume)/(area*T_SAT);
x=x-((rconst*alfv*rhov*(T_SAT-temp)*area*volume)/T_SAT);
end_c_loop(c,t)}
return heat;
the problem is that the x changes for each cell according to the precedent x but not to the adjacent one.
thank you for your help
farr24 is offline   Reply With Quote
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
