January 14, 2015, 22:52 |
Volumetric flow rate UDF
Rep Power: 12 |
Dear colleagues!
I have tried everything and I also cannot find any information about that subject. I would like to hear your suggestion how can I solve me problem. I am trying to write UDF which will calculate volumetric flow [m^3/s] in z direction (3-D simulation) at certain elevations (or areas) along pipe. tab_len[0] =0; /*For this areas I need to find out what is volumetric flow rate*/ for (n = 1; n <= 10; n++) { tab_len[n] = tab_len[n - 1] + length / 10; } I have 10 areas for which I would like to know volumetric flow. I used this tab_len[n] for choosing a cell, if it is contain in one of the areas. For this purpose I created macro (of course all variables are declared): thread_loop_c(t, super_domain) { face_t f; begin_c_loop_int(c, t) { C_CENTROID(x, c, t); y = x[2]; n = 0; do{ n++; if (y <= tab_len[n]) { /* here should be a code to calculate volumetric flow of one cell*/ } } while (tab_len[n] <= y); } end_c_loop_int(c, t) } I tested all of the functions which I know, and nothing seems to work well. The problem is that I use tetrahedral mesh, so faces has some inclinations which make a problem complicated. Maybe the direction of this UDF is wrong and you could suggest me a better way to do it. |
January 15, 2015, 11:41 |
Andrew Kokemoor
Rep Power: 14 |
Do you need this information available for another UDF? If not, a UDF probably isn't the easiest way to measure flow through sections. Check out the Fluent User's Guide Chapter 30 (in particular, section 30.6) for creating surfaces. Reporting the volumetric flow through a created surface should be simple.
January 15, 2015, 11:59 |
Rep Power: 12 |
Thanks a lot for your suggestion. Base on volumetric flow for every area I will choose proper model which I will use during calculation, so I am not sure about the idea with a surface.
January 15, 2015, 12:07 |
Andrew Kokemoor
Rep Power: 14 |
I see. If you separate your domain into multiple bodies with an interface at each location you want to measure, you could loop across that interior face with F_FLUX(f,t).
January 15, 2015, 12:13 |
Rep Power: 12 |
The idea for small domain will work, but at the and I will have domain with around 500 areas.
I think it is still possible to make it using surfaces but I though there is a more automatic way to do it. |
January 15, 2015, 12:46 |
Rep Power: 12 |
Ok so I add some lines of code:
thread_loop_c(t, super_domain) { face_t f; begin_c_loop_int(c, t) { C_CENTROID(x, c, t); y = x[2]; n = 0; do{ n++; if (y <= tab_len[n]) { c_face_loop(c, t, i) { t112 = C_FACE_THREAD(c, t, i); f = C_FACE(c, t, i); F_AREA(A, f, t112); NV_D(psi_vec1, = , C_U(c, t), C_V(c, t), C_W(c, t)); flux1 = NV_DOT(psi_vec1, A); if (flux1 > 0) flux2 += flux1; } mass_flowf[n - 1] += flux2; count++; flux2 = 0; } } while (tab_len[n] <= y); } end_c_loop_int(c, t) } But the flux2 is 0 all the time. The velocity at BS is 0.62 m/s. |
January 18, 2015, 21:41 |
Rep Power: 12 |
Never mind, I was able to solve this problem.
January 26, 2015, 05:38 |
Artem Ponikarov
Rep Power: 11 |
Hello, i have a same problems, Please can you help me?
I should write the UDF to calculate the volumetric flow, in different planes. In order for changing variable value of the source. Please help me! Sorry my bad english. |
January 26, 2015, 12:36 |
#9 |
Rep Power: 12 |
Sure, no problem.
You need to combain the macros which I have showed already. You need to use the idea of choosing the plane base one the algorithm which I have show for cells, but it needs to be done for faces. Then just use: F_CENTROID(x, c, t); y = x[2]; // for z direction, it could be misleading that I use y instead of z // but this is just variable it will be area of a face reflected on z plane. I used: c0 = F_C0(f, t); c1 = F_C1(f, t); to get cells on both sides of face and then from this I used C_W (c,t) to get velocities on both sides. Then you need to get average which will give velocity on face (I don't remember if I tried F_W but I am quiet sure that Fluent will not store values of velocities on faces on interior, but I can be wrong so you can check it, I used F_W on boundary) When you get the velocity on face, just multiply its value with y from example and you will get volumetric flow in z direction on one of the face, you need to add them all together to get the values on specific plane. |
January 27, 2015, 05:26 |
#10 |
Artem Ponikarov
Rep Power: 11 |
Hello, thank you very much! But unfortunately, I'm not good at English, we have a bad level of education. If this is not difficult to you please, post here full udf code, or that part you can, thank you!
January 29, 2015, 04:46 |
#11 |
Artem Ponikarov
Rep Power: 11 |
Harry321, hello. Thank you for helping! Please if you have an article in journal, or something like this, give me a link. If you do not mind, I want to refer to your article.
January 30, 2015, 02:30 |
#12 |
mostafa
Rep Power: 13 |
Hi everybody.
I have a question: I want to compute the surrounding area of a cell in a mass change define macro. I write this UDF but FLUENT doesn’t interpret this UDF. Its error is : line 23: structure reference not implemented I tested 2 ways but both are wrong! Would you help me please? This is my UDF: #include"udf.h" DEFINE_MASS_TRANSFER(LargeBubbles2SmallBubbles, cell, thread, from_index, from_species_index, to_index, to_species_index) { real TotalArea; real NV_VEC(area); int n, i; int phase1_domain_index = 0; Thread *ContinuousPhaseThread = THREAD_SUB_THREAD(thread,phase1_domain_index); face_t f; Thread *tf; /*first way */ for (i==0 ; i<6 ; i++) { tf = C_FACE_THREAD(cell,ContinuousPhaseThread,i); f = C_FACE(cell,ContinuousPhaseThread,i); F_AREA(area,f,tf); total_area +=NV_MAG(area); } /* /*second way*/ c_face_loop(cell,ContinuousPhaseThread,n) { f = C_FACE(c,t,n); tf = C_FACE_THREAD(c,t,n); } begin_f_loop(f,tf) { F_AREA(area,f,t); total_area +=NV_MAG(area); } end_f_loop(f,t) } |
January 30, 2015, 11:21 |
#13 |
Rep Power: 12 |
what kind of multiphase model and what kind of mesh do you use? Try to comment this part: int phase1_domain_index = 0; Thread *ContinuousPhaseThread = THREAD_SUB_THREAD(thread,phase1_domain_index); and use: tf = C_FACE_THREAD(cell,thread,i); f = C_FACE(cell,thread,i); In my opinion if you want area of faces on specific cells, it is better to use this: c_face_loop(cell,thread,n) { f = C_FACE(c,t,n); tf = C_FACE_THREAD(c,t,n); } but you need to remember, if you are going to use it for defining a mass flux, looping over a cell (for mass flux) should give you 0 for mass flux, which comes from conservation of mass, so you need to loop only on positive or negative fluxes. And one more advice. If you want localize where is an error in your code you can comment some lines of a code to see if the macro will run without specific line, or add Message (""); with some text between some line to see where macro will stop. Btw. Enhort have you received my message on privet? I have sent you one. |
January 30, 2015, 12:47 |
#14 |
mostafa
Rep Power: 13 |
hi harry.
I got your message and thank you. my multiphase model is VOF and I run my setup on a structured mesh. unfortunately What you said doesn't work OR I can't understand your answer well. I want to compute the surrounding area of each cell. my DEFINE_MACRO is "DEFINE_MASS_TRANSFER". #include "udf.h" DEFINE_MASS_TRANSFER(name, cell, thread, from_index, from_species_index, to_index, to_species_index) { real TotalArea, NV_VEC(area); int n, i; Thread *ContinuousPhaseThread = THREAD_SUB_THREAD(thread,0); my question is from later part : I used these two ways but both are wrong. whould you tell me what is the correct form and which way is better: face_t f; Thread *tf; first way: for (i==0 ; i<6 ; i++) { tf = C_FACE_THREAD(cell,ContinuousPhaseThread,i); f = C_FACE(cell,ContinuousPhaseThread,i); F_AREA(area,f,tf); total_area +=NV_MAG(area); } Second way: c_face_loop(cell,ContinuousPhaseThread,n) { f = C_FACE(c,t,n); tf = C_FACE_THREAD(c,t,n); } begin_f_loop(f,tf) { F_AREA(area,f,t); total_area +=NV_MAG(area); } end_f_loop(f,t) return (...); } |
January 30, 2015, 13:26 |
#15 |
Rep Power: 12 |
@ Enhort check your privet messages.
@mostafa_zeynalabedin Just use : c_face_loop(cell,thread,n) { /* Here you are "inside" one cell and you are looping over ALL faces but only in this one specific cell */ f = C_FACE(c,t,n); tf = C_FACE_THREAD(c,t,n); /* Here you should put a code to calculate area of a face and sum all of them together. Notice that n is a number id of a face specific for this one cell and program will automatically now how many faces are "sign" to this cell*/ } This macro is used only for ONE cell, so you need to also loop over all cells from the thread (for example interior) for which you desire to have total area of all cells. This loop should be inside a loop for looping over all cells. Using this loop you don't need to use looping over faces. I hope this is clear If no, just ask more question. You can also look at examples from fluent documentations |
January 30, 2015, 15:17 |
#16 |
mostafa
Rep Power: 13 |
Thank you very much harry.
I have used it, but I got surprised that it doesn't work. I got confused! every thing is OK, but the FLUENT doesn't interpret this UDF. I make the UDF very simple but it doesn't work again. UDF : #include "udf.h" DEFINE_MASS_TRANSFER(name, cell, thread, from_index, from_species_index, to_index, to_species_index) { real TotalArea, NV_VEC(area); int n; face_t f; Thread *tf; c_face_loop(cell,thread,n) /*line8*/ { f = C_FACE(cell,thread,n); tf = C_FACE_THREAD(cell,thread,n); F_AREA(area,f,tf); total_area +=NV_MAG(area); } return (0); } the error is : line 8: structure reference not implemented I also checked this one : #include "udf.h" DEFINE_MASS_TRANSFER(name, cell, thread, from_index, from_species_index, to_index, to_species_index) { real TotalArea, NV_VEC(area); int n; face_t f; Thread *tf; c_face_loop(cell,thread,n) /*line8*/ { f = C_FACE(c,t,n); tf = C_FACE_THREAD(c,t,n); F_AREA(area,f,tf); total_area +=NV_MAG(area); } return (0); } I also checked this very very simple one: #include "udf.h" DEFINE_MASS_TRANSFER(name, cell, thread, from_index, from_species_index, to_index, to_species_index) { int n; c_face_loop(cell,thread,n) { } } but it still doesn't interpret! help me please |
January 30, 2015, 15:34 |
#17 |
Rep Power: 12 |
{ int n; c_face_loop(cell,thread,n) { } } This one for sure will not work, like I wrote in previous post this macro is only for one cell in thread. Fluent doesn't know for which one, you need to specify what to do. Check my example in previous posts Here is an example which should work DEFINE_MASS_TRANSFER(name, c, t, from_index, from_species_index, to_index, to_species_index) { int i; face_t f; thread *t112; real A[ND_ND]; begin_c_loop_int(c, t) { c_face_loop(c, t, i) { t112 = C_FACE_THREAD(c, t, i); f = C_FACE(c, t, i); F_AREA(A, f, t112); } } } and in case of a problems try this method for debugging: #include "udf.h" DEFINE_MASS_TRANSFER(name, cell, thread, from_index, from_species_index, to_index, to_species_index) { real TotalArea, NV_VEC(area); int n; face_t f; Thread *tf; c_face_loop(cell,thread,n) /*line8*/ { f = C_FACE(c,t,n); tf = C_FACE_THREAD(c,t,n); /* F_AREA(area,f,tf); total_area +=NV_MAG(area); this lines are commented so if it will interprate without this, the problem is in this lines, if not try to comment next lines until you will find which line is incorrect */ } return (0); } |
January 30, 2015, 16:20 |
#18 |
mostafa
Rep Power: 13 |
dear harry.
I checked your example too, but unfortunately none of them works. and the error is still the same. the problem is about the loop function over the faces of a cell, I mean "c_face_loop(c, t, i)". Maybe this loop is not available in this DEFINE_MACRO, because in each composition the error is the same. I know that the problem is about the c_face_loop but I don't know what is the problem! you said that I should use this function in a cell loop. but I don't want to compute the surrounding area of all cells. I want to do that cell by cell, means that in each cell that this MACRO is called for that cell (just 1 cell) I should compute the surrounding area and the next time for another cell. I think (but I doubt) that FLUENT calls this MACRO in each cell so it knows on which cell should do computation. |
January 30, 2015, 21:42 |
#19 |
Rep Power: 12 |
Could you check if it will run after compilation?
February 7, 2015, 21:02 |
#20 |
Rep Power: 12 |
Hi Mostafa,
Have you been able to solve your problem? I got another error with ACCESS VIOLATION when my macro loop over a faces in one cell. Now I use DEFINE_SOURCE DEFINE_SOURCE(source, c, t, dS, eqn) { int i; real a = 0; real b = 0, cc = 0, d = 0, ee = 0, ff = 0, gg = 0; real hh = 0, test=0, test2=0, test3=0; FILE *fp2; face_t f; Thread *t112; Thread **t11; Thread *t13; Thread *t12; Thread *t14; real vec[ND_ND], A[ND_ND], vec2[ND_ND]; real cent0[ND_ND], cent1[ND_ND]; Domain *superdomain= Get_Domain(1); Thread *tm = THREAD_SUPER_THREAD(t); Thread *fluid_thread = THREAD_SUB_THREAD(tm, 0); Thread *phase1_thread = THREAD_SUB_THREAD(tm, 1);/*which shows the thread of a phase to which macro is attached, but the integer is very strange*/ c_face_loop(c, t, i) { f = C_FACE(c, t, i); t112 = C_FACE_THREAD(c, t, i); F_AREA(A, f, t112); t11 = THREAD_SUB_THREADS(tm); t12 = t11[0]; t13 = t11[1]; NV_D(vec2, = , F_U(f, t), F_V(f, t), F_W(f, t)); } } I use Euler model and I attached this source to second phase. It seems that not all values are stored on faces. I put some Messages to print out ID's of all threads which I declared and values for velocities and non of them show me the ID of a boundary. After producing some numbers for thread ID's and velocities and after some iteration there is ACCESS VIOLATION. What is more t12 and t13 IDs show the same number, ID of the t112 shows integer of a interior and tm, fluid_thread, phase1_thread IDs shows very strange numbers. I try to figure out how to check if values for F_U and F_V are stored for a face but I don't know how to check this. Maybe other colleagues will help to solve this problem . |
Convergence problem with target mass flow rate | ADL | FLUENT | 2 | May 29, 2012 22:11 |
UDF for inlet mass flow rate | rahulsuresh89 | Fluent UDF and Scheme Programming | 1 | October 16, 2010 18:06 |
UDF mass flow rate | Juan | FLUENT | 2 | December 22, 2007 10:29 |
particle, parcel and mass flow rate balance | flybird | FLUENT | 0 | May 24, 2007 11:44 |
How to define mass flow rate using UDF? | SAMUEL | FLUENT | 0 | December 16, 2004 03:55 |
